Seymour Lipkin Plays Beethoven
Posted by: Todd A on 06 August 2005
Who next? I’m hoping HMV Japan comes through on the Backhaus mono set, but I needed something else to sate by demand for the 32. Options abound, and Barenboim and Kuerti beckon, but when browsing Overstock again I came across all three volumes of Seymour Lipkin’s recent cycle on Newport Classic. I’ve never heard of the guy, but the set has received some good reviews, so why not? Lipkin is an experienced player to say the least; turns out he’s now in his 70s and has been performing for a long time. His carefully crafted bio, which is almost the only one that pops up with an net searches, and the few other tidbits I found list Szell and Koussevitsky and Bernstein among those with whom he has collaborated; Serkin and Horszowski were both his teachers. His recorded output is pretty slim – he’s a Beethoven specialist with the concertos, sonatas, violin sonatas, and cello sonatas all on disc – but little else is out there. He is on one of the Bernstein Royal Edition discs playing Stravinsky’s Concerto For Piano And Wind Instruments and there are a few others, for those who want to hear him with a big name artist.
Before venturing into the recordings themselves, I must note that this cycle is different than any other. The potential buyer can choose to buy this cycle in one of two formats: in three 3-disc volumes on conventional CDs, or as MP3 files on one (yes, 1!) CD-ROM with complete sheet music included. At $30, that’s a bargain. I opted for CDs since, in terms of sound quality, MP3 really stands for Manure Pile Cubed. But for those listeners less concerned about sound quality of modern recordings, this may be the way to go. You can order either set directly from Newport Classic (http://www.newport-cd.com) or from your favorite shops, though the CD-ROM seems less easily available.
My usual practice is to listen to the sonatas in order, but this time circumstances conspired against me. My order of all three volumes was split in two. The early sonatas have not yet arrived, so I was faced with a few choices. Don’t listen until all sets arrive. That’s silly. Write up the reviews chronologically while listening out of order. (I occasionally mix up a sonata or two, but I mostly listen in order.) Nah, too much work. The final option is to write them as I listen to them. Easy and quick. So I started with Volume II.
So Op 22 became my first exposure to this pianist’s Beethoven. It’s a good place to start. Lipkin starts the piece off with a quick, vital approach, his playing lean, pointed, and clean. His tone isn’t the most ingratiating, and the sound is a bit sharp, but his basically intellectual approach reminds me to an extent of Friedrich Gulda. The Adagio shows where Lipkin’s age and experience come in handy. While not a very emotional piece, Lipkin’s phrasing and touch both hint at something more personal and moving just below the surface. The concluding two movements both sound more like the opener, and wrap up a damn fine start. No, he doesn’t match up to the best, and though he reminds me of Gulda a little, he ain’t Gulda.
Moving to Op 26 finds more of the same. Sparing use of the pedals and a sharp staccato lead to a choppy sound in parts, though the latter half of the first movement does flow nicely with a nice, rhythmic pulse. The second movement sounds lithe, with a satisfying ebb and flow. The funeral march is cool but dark hued, and if again there is a nice rhythmic pulse to it, it sounds neither funereal nor march like, and the dynamic range is limited. But I really liked it. Go figure. The final movement is quick, pointed, and vital and ends the work on a strong note.
The first of the Sonatas quasi una fantasia opens in manner that hardly sound fantastic; it’s direct, maybe a bit gruff. It’s provides the musical equivalent of a cold shower. A few missteps hardly detract from the surprisingly effective open. The second movement, while not as quick and definitely not as strong as some, is alert and vital. The third movement is quick – but not too quick – and though cool, reveals a bit of soul. For the finale, Lipkin opts to play quickly, with a rough and boisterous sound that is never overdone. Another successful sonata. The Mondschein again finds Lipkin using pedals in a relatively sparse fashion, so the hazy sound delivered by so many in the opening movement gives way to a more directly somber feel. The second movement is relatively slow, in the context of the recording and Lipkin’s approach, yet its lean, pointed and ultimately contained sound is quite refreshing. For the finale, Lipkin opts for a quick, sharp, staccato-laden approach again. While he doesn’t play the piece with great strength, the taut, rhythmically driven approach works to deliver yet another success.
Given the traits of Lipkin’s pianism, I was expecting a less than stellar Pastorale. Yet once again he manages to deliver a fine reading. The opening is just fine, if perhaps a bit choppier than I prefer. It also doesn’t really sing, but it is warmer than some of the preceding pieces. Lipkin takes some runs very swiftly, which works very well. The Andante opens with awkward tempi and phrasing, but improves as things progress. It does take some getting used to. The Scherzo is jaunty and rough, but works very well. The final movement is more standard in conception, being gentler and more traditionally beautiful. So, not a first choice, perhaps, but it is very good.
Crunch time. The critical Op 31 sonatas would help me determine if Lipkin’s got what it takes. Things start off well enough. The first of the bunch again opens with Lipkin’s lean, sharp playing, and the occasionally choppy and broken feel that brings are more than off-set by the rogue wit and charm. Indeed, his sound contributes to the feeling. In the second movement, the long trills are fine enough, but the left hand accompaniment throughout the movement can sound a bit stodgy and stubborn at times. Initially, I was less than enthusiastic, but Lipkin made a believer out of me with his perfectly judged deployment of this approach. The final movement is perhaps not ideally free, but clarity and insistence make it work. The Tempest ends up being a bit maddening. While lean and quick can make a great approach – I’m thinking Gulda here – Lipkin doesn’t deliver the recording I wished he could. His limited dynamics hamper the contrast in the first movement, and he sounds a bit labored in parts, though he no doubt intends this. The second movement sounds terse and cool, with little color. But it works, dammit. The final movement doesn’t swell with emotion and passion, either, but somehow, in ways I cannot fully understand, he makes the whole thing work. That shouldn’t be. But it is. The last sonata of the bunch is the best of the bunch. Lipkin opens the work with meticulous attention to detail, with each note and phrase given its due, but it ends up not being quite fluid or graceful enough. Instead, that roughish charm and with come to the fore. The second movement sounds a bit labored at times, but fortunately things pick up from there. The third movement, while not emotional on the surface, is subliminally touching. The final movement is a raucous good time. So, how to sum up this critical trio. I must confess that there are some things I don’t really like, yet Lipkin somehow manages to pull off something unique: even including the things I don’t like, he manages to make the works work. It’s the damnedest thing.
The two Op 49 sonatas are both fine. The first sonata is basically a straight run through with nary an unattractive quirk or bothersome device to get in the way. The second sonata is meatier. A solid opening, nice rhythmic drive, varied dynamics, and highlighted melodies all work splendidly. The second movement is just plain fun. Not lovely. Not lyrical. Fun. Cool.
In contrast to my initial concerns about the Pastorale, I had high hopes for the Waldstein. Right from the start those hopes were fulfilled. His sharp, pointed, lean style is everywhere evident, and he plays quick, quick, quick. No lyrical opening this. Lipkin adds a bit of heft to the mix, too. His playing also adopts an almost hectic feel. He never loses control, but he never sounds settled in. This extra little bit makes for a strong opener. The second movement ends up not sounding very moving, but it is entirely gripping. This leads to another “how does he do it?” moment, or did for this listener. The final movement opens softly and gently, for Lipkin, with expertly judged tempi and dynamics. The piece swells and moves along beautifully for a while, then it’s back to hectic mode. All told, at the end, this ends up being a remarkable recording.
So too is the final sonata in Volume II. The Op 54 sonata can of course be interpreted in many ways. Lipkin’s particular mix of devices and styles creates a new one. He opens with his Lipkinisms on display, with sharp but not overpowering sforzandi adding some zing. The first movement may not be lyrical, but it flows and invites the listener to pay close attention. The quick trills at just past 4’ in are just delicious. The second movement is gentler than Lipkin’s norm, though it’s still comparatively rough. The deliberate playing is very effective, and it is punctuated by some pretty nifty dynamic swings. Another winner.
To an extent, I have taken the view that Lipkin offers a nice foil to Andrea Lucchesini. Both players are a bit cool and detached at times, but Lucchesini opts for beautiful legato to deliver his message while Lipkin plays in a leaner, harder, more staccato-heavy style. Lipkin also manages something few pianists do: even if I disagree with some of his specific interpretive choices here and there, I cannot resist the overall result. Lipkin plays with such conviction and assured musical knowledge that it becomes impossible to find fault with performances with faults. That’s impressive indeed.
The recordings, which may be new or may date from a few years ago when Audiofon issued some of Lipkin’s recordings (anyone know for sure?) are all clear, bright, and close but not too close. Thank goodness I have twenty more to listen to.
