Quicken
Posted by: John3 on 14 March 2010
Anyone here still using Quicken (2004 version) for their home finances in the UK? A brilliant piece of software sadly discontinued a few years back in the UK but still working fine for me on XP.
My question is - does it work on Window 7 should I change my computer as some point as no doubt I will have to. Dreading the thought of no longer having access to all that history and having to find a replacement.
Posted on: 14 March 2010 by Bananahead
When I upgraded (new build really) to Vista I couldn't find my Quicken disks (I suspect it was a download but I couldn't find that either).
I asked a friend to bring back an American copy and I have been using that ever since (including on 7). The American version works exactly the same as the UK version - you can set it up to use Eueopean currencies (I use UK, Euro and Swiss Franc) so this may be an option for you.
Posted on: 15 March 2010 by John3
Thanks for the reply. Can I ask if you were able to load your existing UK version data files into the US version?
Posted on: 15 March 2010 by Bananahead
Sadly no. I don't know if you do an export as a QIF file if it will then just import it into the new version.
Posted on: 18 March 2010 by Rockingdoc
Good question.
I still rely totally on old Quicken for my accounting. Works pefectly on XP on my laptop, and would prevent me moving to a Windows 7 platform if not compatable.
This suggests old files can be imported
Quicken 2010
This isn't an ad, so hopefully won't fall foul of our administrators.
Quicken 2010
Posted on: 18 March 2010 by fixedwheel
John
Another option for you could be the XP mode in Windows 7 Professional or Ultimate. It basically runs a copy of XP in a Virtual Machine so you can run stuff that isn't 7 compatible.
That's if Q7 doesn't run without problems. It might be fine.
HTH
John
HTH
John
Posted on: 19 March 2010 by Adam Meredith
I have run Quicken under Vista but it doesn't like it and the oddities lead me to wonder if it is entirely to be trusted.
Under XP it is stable and, as many have noted, a very useful home finance tool.
The best (although involved) solution may be to run under XP emulation in Win7.
For the long-term future the latest versions may be worth buying but they will not import data from your existing files.
Below is the answer I received from Quicken - I quote it here as I do not believe it to be a particularly private communication. It may be of help to others and save Quicken multiple replies.
"Thank you for contacting Quicken Customer Care.
Adam, I completely understand your concern and would request you to go through the following points before deciding whether to opt for Quicken for US or not:
1) We can download transactions only from the US banks in Quicken for US. However, we can enter the transactions manually for International banks since the multi-currency feature is available in Quicken. To know more about the multi-currency feature, please visit.
https://quicken.custhelp.com/c...adp.php?p_faqid=4532
To check whether your bank is being supported by Quicken or not, please visit.
http://web.intuit.com/personal...qb1800&qbmid=qbm1700
2) Data can not be converted from an International version of Quicken to Quicken for US, due to a difference in the design of the programs. However, we can create a new data file in Quicken for US and track account under an International bank, manually.
3) We need to have a credit/debit card with a US billing address to place the order on the quicken.com website. Please visit the link mentioned below to know more about this:
Ordering Intuit products from a foreign country
https://quicken.custhelp.com/c..._adp.php?p_faqid=846
[Customer name], please visit the link mentioned below to know about the features of the different versions of Quicken for US. This will help you in selecting the best version suited to your requirements:
http://quicken.intuit.com/comp....jsp?lid=site_banner
Once you have decided, you can click on the version of your interest and purchase it’s download or CD .If you are a Mac user then please visit the link mentioned below:
http://quicken.intuit.com/pers...personal-finance.jsp
You can also purchase Quicken from a retail store or over the phone. To submit a call back request, please use the following link.
http://quickendirect.com/phone
Our representative will call you within 30 minutes. Callback is available between 5 AM to 5PM, Monday to Friday PST.
Note: Questions related to purchasing a product are not chargeable.
If you would like to purchase the download for Quicken, but you don’t have a credit/debit card with a US billing address, then you can also try to purchase the same from retail sites like amazon.com, ebay.com, etc.
I hope that I have provided you with all the necessary details that will help you in deciding whether to purchase Quicken or not and would help you with the purchase as well.
Please let me know if you have more questions. I will be happy to assist you further, as I am committed to ensuring your satisfaction.
Sincerely,
Quicken Customer Care"
Sincerely,
Posted on: 19 March 2010 by Darke Bear
I've recently upgraded my XP to Windows 7 and my Quicken 2000 runs just fine on it. It didn't need emulation mode - just run fine.
DB.
Posted on: 19 March 2010 by MilesSmiles
I'm on Quicken 2007 and the support is now being discontinued, just got an offer for Quicken 2010 at 50%off - guess I'll upgrade now before my automatic account updates stop.
