Newbie Quesion - Forgive mi
Posted by: maserluv on 11 June 2002
Okie...may i ask -
1. Wat cables are included in the cd5?? example - interconnect & power cord??
2. Wat cables are included in the Nait5?? example - speaker cable & power cord??
Or do i have 2 get the interconnect & speaker cables seperate??
Will the speaker cables work wif my current normal speaker??
Geee... thanks!!!
Posted on: 11 June 2002 by Rico
CD5 includes power cable, interconnect, remote, puck.
Nait 5 includes power cable, and IIRC remote.
You buy the NACA5 in the length you require, in white or black - min 3.5m per side.
Please correct me if wrong about the Remotes.
Rico - SM/Mullet Audio
Posted on: 12 June 2002 by herm
Welcome Maserluv,
Rico's right about the remotes. You get one either way. If you're going to purchase a CD5 (new) it's worthwhile trying to wangle one or two extra pucks out of your dealer. It's best to use a new one every year or so, and, given they're just a piece of rubber they're not cheap.
You do get the Din-to-Din interconnecvt, but you don't get the NACA5 cable. The good news however, it's one of the cheapest good cables around.
Herman
Posted on: 12 June 2002 by kevinrt
my nait 5 also came with the naim plugs to fit on the amplifier end of the speaker cable.
Posted on: 12 June 2002 by maserluv
heeheee... thanks guys!!! so i will get -
CD5 - power cable, interconnect, remote, puck.
Wats is puck??
How much is NACA5 (min length 3.5m).... do u think i can get the dealer 2 gv it 2 mi free???
Thanks Once Again!!
Posted on: 12 June 2002 by seagull
The puck is a small disc with magnets and rubber feet which is used to hold the cd in place when you play it (I presume - it may have other functions as well, I'll leave that one to the more knowledgeable members of the forum).
If you had to ask about this you clearly have not had a dealer dem. One of the first questions I asked when I saw the CD5 was "what the puck's that?" smile
I recently bought some NACA5 at £6.25 per metre plus cost of plugs.
what is puck?
You don't know about puck? The entire CD5 revolves around the puck! It's Naim's kryptonite!
Why do you even want to have a CD5 when you don;t know about puck?
Herman wink
oic... so tat thingy counter balance is call a puck.
heheeee s long s cd5 sound nice!!! who care wat its call smile
who cares? we do!
In fact the more posh prefer to call it clamp.
And in olden times it wore a high hat.
BTW where are you from, ML?
Herman
Posted on: 12 June 2002 by Thomas K
Singapore?
Thomas
Posted on: 12 June 2002 by garyi
Oi dats my brover.
Posted on: 12 June 2002 by silklee
Originally posted by Thomas K:
[QUOTE]BTW where are you from, ML
Singapore?
Thomas[/QUOTE]
yap, he's from Singapore.
