DBTs and hypocrisy.
Posted by: syd on 20 November 2003
In a wholly unrelated thread I've been conducting an exchange between myself and Andrew Thomas on my belief that he's a hypocrit.
It goes like this
Andrew Thomas
At the risk (once again) of sounding like a shill for Billy Woodman...
I went from Aktiv Isobariks (3xLK280/SPARK) to ATC Active 50's and have never looked back... The ATC's are just vastly superior to Isobariks (I know, I know, I'm wasting my time). And for £7.5K amps/crossover included the 50's are a relative steal. Go hear a pair - trust your ears Smile
You could take the money you'd save on naim amps and get a better front end, should you feel so inclined.
My work here is done Smile
My response
I went from Aktiv Isobariks (3xLK280/SPARK) to ATC Active 50's and have never looked back... The ATC's are just vastly superior to Isobariks (I know, I know, I'm wasting my time). And for £7.5K amps/crossover included the 50's are a relative steal. _Go hear a pair - trust your ears_
Andrew,
you really are a Hypocritical Tosser. And no just because you put in a smiley doesn't make it the least bit humourous.
Yours in Music
Syd
Andrews reply
Originally posted by syd:
Andrew,
_ _Go hear a pair - trust your ears_ _
I would be a hypocrite if I had claimed there was no difference between speakers.
[This message was edited by AndrewThomas on WEDNESDAY 19 November 2003 at 22:27.]
My reply
Andrew,
I would be a hypocrite if I had claimed there was no difference between _speakers_.
In one thread you you state that there is no difference between cables, the surfaces the equipment stands on, mains arrangements etc unless scientifically proven using DBTs, and now you are telling a person to trust their ears, exactly what all your detracters have being saying all along. Your still a hypocrit.
Yours in Music
Syd
Andrews answer
What you have failed to understand about DBT is that the test is such that people can only use (and therefore trust) their ears.
If the phrase "trust your ears" was taken to its logical conclusion (expecially by subjectivists who use it), they would only participate in (and purchase equipment based on) DBT..
Me
What you have failed to understand about DBT is that the test is such that people can _only_ use (and therefore trust) their ears.
Are you saying that you actually conducted a DBT in the dealers or in your home before buying all of your equipment?
Yours in Music
Syd
Andrew again
What I am saying is that people who use the phrase "trust your ears" and yet refuse to participate in double blind testing are the hypocrites.
[This message was edited by AndrewThomas on FRIDAY 21 November 2003 at 04:33.]
My final post on the other thread
As far as I can tell nobody on this forum has actually refused point blank to take part in double blind testing. Indeed many of your detractors in an old thread became quite interested in setting one up but seemed to get bogged down in the logistics of it all. Mostly they don't think it would change their minds one way or the other. Perhaps you could organise one and invite people to come along to it.
I'd still like an answer to my question
Yours in Music
Syd
I hope I've managed to put it all in as it was on the other thread, but apologise to Andrew if I've inadvertantly fucked it up.
Yours in Music
Syd
Posted on: 21 November 2003 by Phil Barry
What's the purpose of this thread?
Phil
Posted on: 21 November 2003 by Paul Ranson
Why is this so difficult?
The only time you can be truly using your ears is in a properly conducted DBT. All other listening is contaminated by non-aural influences.
For an example the existence of 'direction' markers on cables is symptomatic of the desire to make the 'right' decision and not trust ones ears. How many people actually determine 'correct' directionality aurally?
Paul
Posted on: 21 November 2003 by JohanR
The only BT I have done was with a classical LP that was recorded digitally on one side and analouge on the other (the same performance on booth sides, obviously). Carefully avoiding looking on the label I put it on the LP12, playing a part of one side and then the same part of the other side.
There was a clear differnce and I had no problem telling wich side was digital and wich was analogue.
Then I looked on the label. I was wrong!
But, of course, in BT terms it was a "hit", a difference was detected.
To make it completely DBT I should have flipped the LP in the air, put it on again and been able to tell wich of the two sides was on now. Didn't do that, but maybe I will tonight!
JohanR
Me, I turned my Burndy round 'cos my ears said it sounded better that way.
I suspect you're a rare bird....
I've done it in the past with a home made cable, but I wouldn't warrant that I'd make the same decision the next time.
But isn't music rather more than just sounds or notes or am I missing the point of hi-fi?
I don't see the relevance of that to whether you should use the senses other than hearing to choose which hifi sounds more like music...
Paul
Posted on: 21 November 2003 by Nime
Originally posted by JohanR:
There was a clear difference and I had no problem telling which side was digital and which was analogue.
To make it completely DBT I should have flipped the LP in the air, put it on again and been able to tell which of the two sides was on now. Didn't do that, but maybe I will tonight!
JohanR
A brave chap for admitting it here! But if you really don't want to be allowed to spend another penny on HiFi for the rest of your married life: Get your wife/ girlfiend to do the "swapping" for you. It will take years to build up enough "cred" to be able to buy even a new set of cartridge screws! Big Grin
Nime
Everyone has the right to be wrong.
Posted on: 21 November 2003 by Frank Abela
syd
I think I may have looked briefly at that other thread, and after noting the aggressive, derogatory comments I decided to move on to a more interesting, less insulting, thread. I'm guessing that thread got pulled? If so, I wholly applaud the decision to pull it and rather hope that the Naim moderators pull this one too!
Ah, no, my mistake. I see that the other thread is still there. Ah well...I live in hope.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
Emotions are governed by more than what you hear so to choose hi-fi in a cold clinical manner would suggest that you aren't judging it under normal listening conditions.
IMO you should sit down with a bottle of wine and just play tunes. That's what the thing is for.
But, do cables sound different when reversed? How do we resolve that question? It's a claim that is, on the bald face of it, absurd, so the demonstration must be unarguable.
I don't know if you saw the 'Bible Codes' Horizon programme last night, but it illustrated some of the problems in a different context.
Paul
Posted on: 21 November 2003 by MichaelC
Originally posted by Tom Alves:
And I know my hi-fi sounds better than anyone elses so I'mm happy. Smile
Tom
Actively enjoying it all
And that, surely, is what it is all about.
Mike
Posted on: 21 November 2003 by Martin Payne
My prefered auditioning technique is to get the stuff home, drink some wine, potter around, eat, chat and listen, i.e. behave normally. I doubt if you could DBT that experience.
Tom,
If you could hide the items being compared (or the tweak applied) I don't see why you couldn't run one config for a night (or a month), and just live with it as you normally do.
Swap over and listen the same way the next night/month.
I don't see why this would be any less valid than a two minute snatch under "stressful" conditions, and should be much more of a real-world test.
cheers, Martin
E-mail:- MartinPayne (at) Dial.Pipex.com. Put "Naim" in the title.
Posted on: 24 November 2003 by JohanR
Music works emotionally. Emotions are governed by more than what you hear so to choose hi-fi in a cold clinical manner would suggest that you aren't judging it under normal listening conditions. My prefered auditioning technique is to get the stuff home, drink some wine, potter around, eat, chat and listen, i.e. behave normally. I doubt if you could DBT that experience.
Agree a 100 percent.
BUT! There is of course allways the doubt that I hear what I hear because I knew that the new pairs of 135:s substituting my 180 SHOULD sound better.
I did the DBT test again this weekend as promised/threatened. Hearing a small part of the record, swapping it over and hearing it again, swapping back etc. etc. It IS a quite stressing experience that, as Tom says, has nothing to do with the normal way of listening to music. But after doing it six times and getting the same result (as in prefering the same side) five out of six times one can safely say that the difference between an analogue and a digital recording, transferred to vinyl, IS detectable under DBT conditions.
Anyone dare to do it with respect to the sexing of cables? Or maybe different Naim amps? In these cases I gaver one needs a friend to help out...
JohanR
Posted on: 24 November 2003 by andy c
Sheesh!
My wife and I didn't do blind testing over a recent weekend when I'd some new kit to work out the best upgrade path. (282/250mk2/XPS2).
I feel I may have not conducted the listening tests properly now having been able to clearly view all equipment throughout! Big Grin
On a more serious note if I have a piece of kit/cable/stand or whatever and with no harm to anyone else I can try something like differant cables etc (should the need arise) then i will.
And if I'm considering paying out for it but it doesnt sound and better than what I already have then i won't swap!
On another note how do you demo a mains spur in your own home? (uh oh said it there then didnt i)
Posted on: 24 November 2003 by Laurie Saunders
Syd...if Andrew T went from active Isobarics driven by Linn LK280s, I am hardly surprised he never looked back......to say that ATC 50s are better,is, IMHO a classic case of "damning with faint praise". I can`t think of many amps that wouldn`t sound better IMHO
My issue with DBT is that it is largely irrelevant, as I have pointed out numerous times. All a prospective purchaser/user has to do is to install the item and make up their own mind. As to what others have said....trust your own judgement (ears)
Laurie S
PS... isofar as anyone who actally parted with hard earned cash for (early) Linn amps/cd players.....no wonder they need double blind testing....their own hearing must be highly suspect
Laurie S
Posted on: 24 November 2003 by Paul Ranson
Laurie, an LK280 is a rather better amp than a chrome bumper NAP250. This proven by extensive 'just listening with a glass of wine'....
Paul
Just for the record, I also test each cable aurally for directionality, and stay with the direction I find best, regardless of any direction markers.
That makes at least two of us, Tom
Laurie s
Paul...that is your opinion, which you are perfectly entitled to, and obviously one I do not remotely agree with. My point was that someone who finds merit in such devices (as the LK280) is probably the least likely to have any worthwhile advice to give me ,or any other who shares my preference for Naim amplification
Laurie S
A preference for Naim amplification (or even CDPs and speakers!) doesn't change the laws of physics, or make the preferrer objective about their hearing.
IMO there is something completely broken about the ear/brain interface of someone who doesn't like an Aktiv Isobarik system, I've no idea what goes on in Harrods, I've never been.
Paul
Frank....regarding "agressive" comments....what about the principle of free speech...are suggesting banning comments that you find unpalatable? (assuming that they do not break rules of racial/sexual/....discrimination or are in any other way illegal.)
Laurie S
Posted on: 25 November 2003 by Alex S.
Nothing kills music faster than an Isotek Cube. Anyway, I've just listened to The The's Soul Mining, that was a "shock and ore performance".
Alex
Posted on: 25 November 2003 by Andrew L. Weekes
Best thing I've read in this thread so far Wink
Good album, BTW.
A.
