Hicap SNAIC
Posted by: Bosh on 30 March 2003
I've got some surplus SNAICs, which one belongs to the Hicap the 4/4 or the 5/5 pin?
Posted on: 30 March 2003 by Naimed
If your configuration goes like this -> Pre/Hi/Pow then the 5/5 goes from the pre to hicap (socket 4) and the 4/4 goes from the hicap (socket 3) to the amp.
Posted on: 30 March 2003 by Bosh
Thanks Naimed, which would you use if you didnt have the Hicap, a 4/4 or 5/5
Hi Bosh,
Without the Hicap, the 4/4 goes from the amp(assuming 140, 150, 180) to pre. The 5/5 is provided with the Hicap and the 4/4 provided with the NAP.
Posted on: 30 March 2003 by garyi
Bosh, this is not a choice thing, if there is no hicap connected you need to use the four pin, with the five pin blanking plug in the back of the pre amp.
regards.
regards.
Cheers for that.I just needed to ensure I didnt flog the one that comes with the Hicap which I currently use for the prefix
