What you should i do know?
Posted by: Charlezz on 20 June 2001
cd3,5/Hicap
Nac102/Supercap
Nap180
Linn Kan2
What should be my next upgrade?
Thanks a lot.
Charles
If I did have to do something to it I'd probably ditch those horrible bandwith limited speakers which are obviously strangling your system and replace them with something decent...
Wonder if that bait will catch anyone...
Steve
Mmmm, bait...
If this system were mine, and I had loads of money:
1) Definitely a better CD player as it would seem to be the only source - I will be honest I have never liked the 3.5 very much, even with a Hicap attached. The CDX would be a good starting point, though the CDI, CD2, and CDS1 can be really good S/H buys. A CDS2 is pretty much good enough for Kans! I would be very happy with this system just by upgrading the source, the stuff below IMHO is not needed. Just max out the source.
2) Preamp to 52, great that you already have the Supercap.
3) Power amp to either 250 or 135s.
4) Then, and only then do the Kans seem slightly weak, though there is next to nothing this side of SBLs worth thinking about to replace them...
Tony.
1. Second hand CDS1 (£2k) = upgradable to CDS2
2. s/h SBL's (£1k)
3. a 52 when funds permit.
-=> Mike Hanson <=-
It doesn't seem to be your point of view.
Could you tell me more about that?
Thanks in advance,
Yours trully
Charles
About the speakers...I've no problem with Kans, I used to own a pair. I agree with Tony that the Kans aren't actually weak, however, I do think SBL's are much better. As usual, get a dem' and decide for yourself.
I would sell the 3.5/hicap and buy:
CDX
Then sell the Kans and buy:
SBL's
Then sell the 102 and buy:
82
Then buy:
XPS
Bri
ca me fait rire que tu me dises cela car figure toi si j ai seulement des Kan avec un systeme pareil c est que j economise pour acheter plus tard une paire d ascent, mais pour l instant elles sont trop recentes et il est donc impossible d en trouver d occasion.
Des qu il sera possible d en trouver d occase je me mettrai en chasse...
a+
Charles
For £1600 they will upgrade your CDS1 to a CDS2 and modify your Burndi lead to work with your existing CDPS.
If you can pick up a second hand CDS1 ...this is a good way to get to own a CDS2 which is a great improvement on the earlier model.
It would be well worth paying the extra for the new Black burndi.
I have just had such an upgrade done and I am expecting the equipment back very soon
CD3.5/SuperCap
102/HiCap
Should theoretically be better in some ways, or possibly many. Go on, try it!!
Best
Mark
(an imperfect
forum environment is
better than none)
