Does NaimUniti read ID3v2.4 tags?
Posted by: Tom_W on 11 December 2009
Tom
Posted on: 11 December 2009 by AV@naim
UPnP = It's down to the UPnP server
USB = At present, No
If you embed 1.1 tags as well, then it will pick up those fine. For compatibility, having 1.1 tags is a wise move.
Posted on: 11 December 2009 by Tom_W
Ok, thanks.
Will USB read v2.3?
What are Naim's views on future compatability? i.e. do they view v2.4 as a standard that will be embraced?
N.B. For Foobar users, Foobar saves in ID3v2.4 by default unless you specify otherwise in advanced preferences.
