2nd system speaker choice
Posted by: Peter Stockwell on 12 April 2001
I'm going to be looking for a used pair of small, magnetically screened, speakers to use very close to a wall and in close proximity to a TV screen. Budget about € 200.
one model I've considered looking for are used triangle Titus XS, for the moment I haven't seen a price on these, but the fit the bill for the size. Kan's would be suitable size wise, but I fear that the will play havoc with a TV screen.
The amplifier will be an EL34 pushpull.
Peter
Posted on: 13 April 2001 by Martin Payne
I've been running Kans about 12" from a 29" Sony TV for the last month or so.
No problems yet. For info, the TV is pushed into the corner of the room, and the speaker is close the the front-tight corner of the TV.
Don't blame me if you get a problem, though!!!
BTW, putting a big TV between small wall-mounted speakers is sure to mess up the sound.
Martin
Posted on: 16 April 2001 by Peter Stockwell
The speakers will be used for TV sound, the main rig is in another room.
Peter
