Mishap-short in 110-what values are the wire wound resistors?
Posted by: leslie on 27 April 2002
The 110 has 4 wire wound resistors on each circuit board which have been damaged by a short.. Does anyone know the values and rating of them? If you do can you describe them from L to R looking towards the back of the amp. Many thanks.
Posted on: 27 April 2002 by David Dever
R22 & 8R2--but this isn't likely to be all that's damaged. Consult your local distributor technician.
