B&W DM600 speaker terminal question
Posted by: ARC on 25 November 2003
I've purchased a pair of B&W DM600 S3s and want to use 4mm Banana plugs. However, I'm a bit confused (it doesn't take a lot) the speaker sockets seem to have plastic plugs wedged in them. Should the plastic plugs be prised out to accept the plug? There's nothing in the instructions and the shops now shut and I'm keen to give them a go.
Brendan
Posted on: 25 November 2003 by Geoff P
Brendan
Yes.
They are a bit tight but try gripping them with a pair of pliers.
regards
GEOFFP
