New LP12 plinth/top plate
Posted by: Tim Jones on 09 November 2001
Anyone know how much this would cost? Apart from making my TT look new(ish), would it have any sonic benefits?
Yours in anticipation.
Tim J
Posted on: 10 November 2001 by Andrew L. Weekes
Is the best way to get a nice finish without streaks etc. on stainless steel.
Small amount on a cloth should do it.
Andy.
Posted on: 10 November 2001 by Mark Dunn
Andrew:
Re: Baby Oil
How many babies are required for a typical top plate and how are they processed?
Best Regards,
Mark Dunn
Posted on: 10 November 2001 by Mick P
Chaps
Assuming it is stainless and that there is no laquer etc, baby oil rubbed in with very fine wire wool will produce a mirror like finish. But only use the very very fine stuff.
To prevent damage to surrounding componets, play safe and use autosalvo and a cloth.
Mick
Posted on: 10 November 2001 by Barnie
Originally posted by Mr Pig:
Is your top plate badly scuffed or something? You can't just buff it up again? Cleaning the top plate is a pain, best not to go there, but it can be done. Have you polished your platter?
No, I don't think replacing these two parts would make much of a difference to the sound but if your plinth is a mess a nice one would make you feel a lot better :0) My wife had an old LP12 with a brand new plinth and the plinth does make it look like almost a new deck.
Mr Pig http://www.photo.net/photodb/image-display?photo_id=320102&size=sm
I believe a new top plate is part of the Ninja mod that mana have done in the past.
If you have an external PSU the top plate can be manufactured without a cut-out for the switch,I believe the Ninja mod involves this along with thicker stainless steel.
Barnie.
