HDMI, DVI and HDTV tuners
Posted by: Brucie on 29 June 2006
Dear AV people,
Can someone explain to me the differences between HDMI and DVI and the role of an HDTV tuner?
At the moment I think that once we get digital broadcasting, the HDMI socket is the one to use which will also enable HDTV (assuming one has the HDTV tuner?). The DVI is for connecting a DVD player to the plasma assuming your DVD player has a DVI output (digital to digital connection so to speak)?
If I get a new plasmas TV should I check that both HDMI and DVI are on it?
ta
Bruce
Posted on: 29 June 2006 by Tuan
HDMI = DVI + audio {all digital}
You can have an adapter to convert a HDMI connector to a DVI connector but the audio signal has to be input using other connections [standard RCA]
Posted on: 30 June 2006 by Mike1380
You don't need both HDMI & DVI (although it's nice to have both), but I wouldn't buy a screen that doesn't have at least two HDMI sockets.
As for an HDTV tuner...
Current digital tuners (set top boxes and tuners built in to TV's alike) can "see" the HD channels... but they can't actually give a picture from them
It'll be a while before such technology gets built into a telly, and given the breadth of HD content being offered up by Sky and cable, I doubt that you'll get many options on watch to watch a year from now without getting SKY, Telewest or NTL involved in your system.
Posted on: 17 July 2006 by rgame666
I think the bigger issue is HDCP - don't matter how many HDMI sockets you have if bugger all will talk to your TV.
Posted on: 18 July 2006 by Brucie
HDCP?
thanks
Bruce
Posted on: 18 July 2006 by AV@naim
Hi-Bandwidth Digital Content Protection
Basically copy protection
http://en.wikipedia.org/wiki/HDCP
Posted on: 22 August 2006 by jamesm
it seems that the pioneer 32" plasma has only one HDMI output.
has anyone tried using an external box that has multuple HDMI outputs and if so what would you recommend?
thanks
kerry
Posted on: 22 August 2006 by Mike1380
Hmm...
Smallest pioneer plasma I've encountered is 42", not 32"... and certain versions have one HDMI input... some have 2
Guessing you do mean input - a HDMI output on a screen wouldn't be much use Smile
Posted on: 23 August 2006 by jamesm
yes meant 43" not 32"--and yes input. a little proofreading would go a long way
in any event, can anyone answer the question?
