CAT 5 av2?
Posted by: v_j_r on 28 November 2010
Is this cable critical for OSD setup? is this a standard Cat5 or other as i cant seem to bring up OSD on the DVD5 when connected any help please.
Posted on: 28 November 2010 by garyi
I must confess that I have no idea what you are on about.
I'll asumme I am missing something but:
There is no ethernet connection on the DVD5 or the AV2
I think they might have something that looks like it but believe its for maintenance.
I am happy to be told other wise.
OSD is the video output of the DVD5 no?
Posted on: 28 November 2010 by Dungassin
I'd have to go and dig out the manual to check, but I think you are talking about the crossover CAT cable to connect the DVD5 and AV2 together. IIRC all this gives you is the AV2 information on screen. Hardly worth the effort IMO, and when I reasssembled my AV system for the first time, I didn't bother putting it back in. Smile
Posted on: 28 November 2010 by v_j_r
Many thanks is there a difference in the a crosseover cat5? or are they all the same. Big Grin
Best Regards.
Oh fair enough there is something there then.
Sounds like he wants a patch cable? It could be configured especially for the task so would presumably need to speak to your dealer.
[QUOTE]Originally posted by v_j_r:
QUOTE]
OK. I'll refine my original answer. Just checked the manual for DVD5/AV2. The info is on pages 11 and 12. It's an ordinary CAT5 cable (not crossover - sorry, got that bit wrong). If you really wanted to, you could use a CAT6 or better, but no point really! i.e. any CAT5 cable will do. It's not carrying audio signal, so don't waste your money on an expensive one.
As I said, all it really does is let you control AV2 functions using the OSD (on screen display) generated by the DVD5. Nice if you really want that, but I can (and do) live perfectly happily without it.
I would suggest you check with your dealer or Naim support (email them) that it is not a crossover cable. (wouldn't be the first time I was wrong!)
Posted on: 28 November 2010 by GreenAlex
Jepp. Plain old cat5. No crossover. Cheapo 1 quid cable.
I find it really helpfull because it makes setting everything up properly much easier. I quite like doing it via a proper OSD on my plasma.
Sure, you can do without it, but it's there, so why not use it.
And they come in a nice green, so looks pretty neat, too Big Grin
Oh, on top of the setup-routine, the DVD5 will switch the AV2 to the proper inputs if you use the cat5 connections.
Meaning, if you have an analogue and a digital connection and call them "CD" and "DVD", the DVD5 will recognize the format and switch the AV2 to the correct input.
Also quite nifty.
It's possible, but I am not sure, that sending rc-commands to the DVD5 will be forwarded to the AV2, but I am not sure because I never covered the AV2's ir-rx.
The displays are linked for sure. Maybe other features like volume are but as I said, I never tried it.
Mainly of interest if the AV2 is on a lower shelf with blocked view or in some kind of enclosure and the DVD5 is in the open.
Posted on: 29 November 2010 by v_j_r
Many thanks for all the replies much appreciated, but dont laugh "i cant seem to get it up" the OSD that is hehe Big Grin even though the AV2/DVD5 are connected with a Cat5 what am i doing wrong?. Roll Eyes
Best Regards.
Posted on: 29 November 2010 by GreenAlex
Sounds to me as if maybe you plugged it in the wrong socket.
Nope i did'nt have in the wrong hole! i sorted it with a standard UTP cat5 rather than one with all the comms in/out etc etc so all done now. Big Grin
Best Regards.
