unity gain
Posted by: neil w on 22 January 2003
this may be old news but unity gain is now available for the 52 , just sent mine off
neil
Posted on: 22 January 2003 by Martin Payne
I presume it's just on one input?
How much are you being charged?
cheers, Martin
E-mail:- MartinPayne at Dial.Pipex.com
Posted on: 22 January 2003 by John
What is unity gain?
Posted on: 22 January 2003 by Manu
It's a way to by-pass the volume pot of a preamp to assure a gain of one (output=input).
This is specially useful for a home-theater processor. This way you can use your stereo system to play the left and right front channels witout bothering of the volume level of your preamp.
Emmanuel
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
Posted on: 22 January 2003 by Jay
Available on the 82 as well per-chance?
Jay
Yabba, dabba, doooooo
Posted on: 23 January 2003 by neil w
martin
you loose 1 tape loop
also got qoute from chord on cable
2 phono - 5 din in 5mtr chrysalis £60
cobra £80
jay
yes it is dont know cost of converting 82 but was told that the 52 is very labour intensive ie 2 boards ect
Posted on: 23 January 2003 by Andrew Randle
Unity gain is particularly useful at blowing up your loudspeakers Wink
Andrew
Andrew Randle
Linn Binn Sinner
Posted on: 23 January 2003 by Manu
Not more than a volume pot at 12o'clock on a CD.
Emmanuel
Posted on: 24 January 2003 by Martin Payne
Manu,
I presumed that unity gain is the same as volume control at max?
Even 12:00 would be hugely loud for me.
cheers, Martin
Posted on: 24 January 2003 by Manu
Not at max, 12:00 is approx unity gain... and yes, it is very loud.
Emmanuel
Posted on: 24 January 2003 by Morri
I have been quoted £120 -£150. It depends on the spec of your 52 as there have been various small changes over the years.
Posted on: 25 January 2003 by Geoff P
Emmanuel
It's not out of control though, since you can back off the volume at the audio source you have connected to the "unity gain" input.
However I have a question of my own. Does the signal get fully processed by the NAIM pre-amp circuit so you get the benefit of your higher quality NAIM kit?.
I think the answer is yes but can anybody confirm that?
GEOFFP
