Do you know which WiFi standard is used for Naim Uniti (or UniQute) connection : 802.11g or 802.11n ? 2,4 Ghz or 5 Ghz band ? I did not find this information in Naim documentation.
Posted on: 10 February 2010 by gone
from the manual....
Note: NaimUniti is compatible with most commonly used WiFi standards. Routers that support 802.11b and 802.11g will work, however those with 802.11g compatibility are recommended for best results. Note: NaimUniti cannot connect to a “hidden” wireless network.
Hope that helps
Posted on: 10 February 2010 by malicorne
Thank you !
Posted on: 10 February 2010 by Former member
Its a git with some though. It just wont find them. Stu
