second hi-cap
Posted by: AL4N on 05 January 2004
i have installed my new hi-cap and have noticed that the old hi-cap is connected to the 2 135s and my new hi-cap is only connected to the 82,just curious,is this right?My dealer is not open till tomorrow,and will lay any fear's i have to rest,but being as impatient as i am,i can't wait.
Posted on: 05 January 2004 by Tarquin Maynard - Portly
Alan
there is a connections guide on the main Naim site
Mike
On the Yellow Brick Road and Happy
Posted on: 05 January 2004 by AL4N
cheer's
Posted on: 05 January 2004 by Geoff P
Alan
You have probably figured it out anyway but on an 82 only one HiCap carries the signal to the power-amp.
When you add a second HiCap to the 82 it does not need to be connected to the power amp(s).
The connections guide will help you identifiy which HiCap socket is used to carry the signal and then you should make sure that is the one you connect your 135's to.
GEOFF
