My Nac 52 is powered by the original 52PS supplied, what are the benefits of upgrading to a Supercap and is there really such a big difference for the amount this would cost?
I understand there might be a second hand market for the 52PS as it can be used to power other Naim equipment (CD players???) ..maybe using a modified Burndy? Is this the case and what would be a reasonable price to expect to ask for it in order to trade up please? This would certainly be a big factor in offsetting the cost.
I appreciate that the only way to decide is to actually listen and make one's own mind up ...but others may have already done this and have valuable comments to make.
Thank you
Posted on: 23 May 2001 by Scott Mckenzie
The general jist I get is that upgrading to the Supercap would be the best move since inventing the wheel. Seriously I think it would be a good move to make if you can afford it, I too am unsure as to the value of the 52PS but I am sure someone will be able to help.
Scott
Posted on: 23 May 2001 by David Dever
I know that you can use the CDS1 power supply like a supercap via a modified Burndy cable. I have not heard that you can do this with a 52PS though.
Uh, no...the 52PS is plug-compatible with a modern NAC 52, and vice-versa with a SUPERCAP. At this rate, there are likely very few original 52PS units out in the field.
The CDPS doesn't even figure into the equation, as it has far fewer voltage rails.
David Dever, NANA
Posted on: 05 June 2001 by Michael
After a demo at my local dealer I have decided to upgrade my 52PS to a supercap.
Thanks for the helpful info from contributions above.
I was amazed at the musicality and clarity of the 52 using the Supercap rather than my original 52PS.
For your information the current cost of the upgrade is £1148.
Thanks once again
Michael
Posted on: 12 June 2001 by Michael
So that the two threads are closer together I have posted this!
Will report on my new set up when it is all up and running!
But ...yes..when you can afford it ....GO FOR IT!!
