Confusion over the 1.6x factor for my Canon 20D and 40D.
Posted by: Tony Lockhart on 30 December 2007
Ok, I understand that the sensor on my DSLRs is smaller than a 35mm film frame so that, for example, a 50mm lens on my 40D will now be the equivalent of an 80mm lens on a full frame or 35mm SLR.
However, while pondering if there was any difference in the perspective produced by an 80mm lens on a full frame and a 50mm on my 40D I held my 40D upto my eye with the 17-85mm lens set to 50mm, and hey presto, what I saw through the lens matched what I could see through my other eye. Just to double check myself I set the lens to 17mm and zoomed til yet again the view through the viewfinder matched what I could see through my other eye, and hey presto, it was roughly 50mm.
Just to double check again, and this bit is sad, I held my old Olympus OM1n with its 50mm f1.4 lens upto one eye and my 40D with lens set to 50mm upto the other. No difference in what I could see. I also tried this with a Tamron 17-50mm lens that, unlike my 17-85mm, isn't specially for smaller sensor cameras.... just the same.
Am I missing the point here? I doubt whether my 20D and 40D have full frame sensors!
Tony
Posted on: 30 December 2007 by DIL
A 50mm lens is a 50mm lens is a 50mm lens, irrespective of what camera it is put on, so the perspective will be the same. However, due to the sensors (or film) being different size, you will see different amounts of the image. This is why a 50mm lens mounted on your 40D is said to be equivalent to an 80mm lens. ie you'd need an 80mm lens on your OM1 to see the same (reduced) field of view you see on your 40D.
/dl
Posted on: 30 December 2007 by Tony Lockhart
Dave,
Surely, if the 50mm focal length on my 40D becomes, according to all the photographic press, an 80mm equivalent, then surely the scene in the viewfinder should show this equivalent?
If any photographers here could just check this out for themselves I would appreciate it.
Tony
Posted on: 30 December 2007 by Steve2701
Tony,
A quick google on 'fovcf' - field of view crop factor will give you a huge amount of reading...
A 50mm lens on non full frame canon cameras (which happen to have a fovcf of 1.6 or thereabouts) only uses the central part of the 50mm image that falls upon its sensor - hence making it 'appear' that the lens is actually 80mm - imagine zooming into a standard image at its centre by 1.6 times - and losing the outer edges.
the digital picture.com is a very good resource for canon based equipment... and has an excellent feature on this.
Posted on: 31 December 2007 by icogs
Tony,
What you are experiencing may be due to some degree of magnification in the viewfinder. The angle of view, and therefore the perceived perspective*, of a 50mm lens with DX format will indeed be the same as an 80mm with 35mm format.
The basis for what is termed a 'normal' lens is based on the following observation: When a person views a photographic print (or any image for that matter) they will be most comfortable viewing the image from a distance equal to the diagonal of the print (this does not hold for very small prints where holding it so close strains the eyes, nor for very high aspect ratio 'panoramic' formats). A normal lens is one which will produce a print that, when held at this optimum viewing distance, will show the scene as it appeared to the naked eye. It turns out that this occurs when the taking lens is at a distance from the sensor/film plane equal to the diagonal of the sensor/film format i.e. when focused at or near infinity(true most of the time for most scenes) the format diagonal equals focal length. Therefore a true 'normal' lens for 35mm film is actually 43mm and not the 50mm conventionally supplied - which equates to 27mm for a DX sensor. I think what you are experiencing is a result of the viewfinders imposing non-optimal (in the above sense) viewing distances and each viewfinder being different in that respect.
*lenses do not actually alter perspective, only angle of view. The eye, however, interprets otherwise.
Posted on: 31 December 2007 by Tony Lockhart
It's just strange that the view is pretty much the same as the view through the viewfinder of my OM1n with 50mm lens attached. I appreciate that the viewfinder tells a few porkies, but 60% of the magnification doesn't go missing!
Tony
Posted on: 31 December 2007 by BigH47
It's just strange that the view is pretty much the same as the view through the viewfinder of my OM1n with 50mm lens attached. I appreciate that the viewfinder tells a few porkies, but 60% of the image doesn't go missing!
You still don't have the same view as the CCD though. It's as if the picture is bigger than the CCD .
What you need to do is look through the VF and then take the picture without moving and see how much of that view is taken, if all of it is there, then I'm as mystified as you.
The viewfinder shows about 95% of what the image will contain. However, this is always about the same at sub-pro SLR level, film or digital.
Tony
Posted on: 31 December 2007 by Exiled Highlander
Tony
Does
this help at all?
Jim
Jim,
Thanks for the link. However it just backs up what I'm saying. I 'should' see the equivalent of an 80mm lens through the viewfinder with a 50mm lens fitted but I'm not! I'm seeing the same thing as I do through my old film SLR with its 50mm fitted..........
Tony
