Aerolam
Posted by: Peter Stockwell on 22 April 2001
thanks.
Peter
... a bit later ...
I've found from searching the web that it's now called hexlite. I'm looking for a source in France, ideally, but the UK would be ok. It's made by Hexcelcomposites, I sent them an e-mail.
[This message was edited by Peter Stockwell on SUNDAY 22 April 2001 at 10:03.]
try here for a starter...
http://www.conservation-by-design.co.uk/boards/boards21.html
In fact,a quick trawl using my favourite search engine (www.google.com),using the word "hexlite" as the search word,reveals quite a few bits and pieces of info
Hope this is useful...
Chris
I'd be interested to know how it turns out if you do.
But just don't tell Russ Andrews
AndyM
PS I thought aerolam was made from aluminium, rather than fibre?
Peter
I couldn't find aerolam on french RS site.
Peter
If they are not interested in supplying you in "small" quantities,then you could "politely" enquire as to location of their stockists in your local area,perhaps you could get some that way.
Chris
Peter
look in the 'Engineering materials' book, which is book 5 page 171. listed as 'composite boards'.
Aluminium/Aluminium
board size Stock No. price 1-4 Price 5-7
300/300/12.7 325-7445 £40.18 £36.16
480/600/12.7 325-7451 £90.42 £81.38
GRP/Nomex
board size stock No. Price 1-4 price5-7
300/300/12.7 325-7423 £66.18 £59.56
480/600/12.7 325-7439 £112.69 £101.42
V.A.T. & P&P must also be added!!
Telephone for RS 01536 201 201 idont know what the code from France is.
Fax 01536 201 501
http://RSWWW.COM
I hope this is of help. RS. Does not strike me as cheap! I use a bit of the GRP/Nomex under my pre-amp and it did make a worthwhile improvement. However, i did not pay for it (a strange gift). Also the subchasis of my turntable is made from 2 layers of the carbon fibre stuff laminated together and this does work very well. But then again I would think that wouldnt I.
Have you got a picture of the turntable that you built? How does it compare with, say, the LP12?
John
you're right +- 100GBP is not cheap for a piece of board, but that's the stuff I'mm looking for. Preferably in a 6,35mm thickness or thereabouts. I'll keep the UK reference in mind. I tried it on the the French site ... they don't have it.
I'll keep looking for a french supplier for the moment.
Peter
