Karma or Troika?
Posted by: Alex S. on 29 August 2001
What's the forum advice?
(Please don't tell me to buy an Aro and keep the DV20-X I already have - its nearly nackered and I don't have adequate tonearm funds).
Alex.
I remember the Troika being a significant upgrade from the Karma.
Did you ask them why they gave that advice Alex?
Steve B
controversial eh?
i'd go for a newer design anyday. all this talk about kans better than sbls, karma better than XX1-L, wobbly quadraspire better than mana, nait 2 better than 32.5/Hicap/250 is just making me laugh. this place is more bizarre than the mana forum.
Paul & Steve B. The guy I spoke to seemed to know his stuff and didn't seem to be pulling a fast one. He said the innards of both cartidges were identical as far as he knew and thought the 3 point fixing on the Troika was like claiming you needed 5 wheels on a car for extra stability. Perhaps its the single metal casing on the Karma which allows him to do a better job - less to go wrong perhaps.
Maybe I should trust his advice - a rebuilt Karma could be better than a rebuilt Troika even if the reverse was true of each off the shelf. Anyway he promised that if I was in any way dissatisfied with the Karma I could swap it with a Troika for no extra money.
Alex.
Originally posted by Alex S:
_Dev_ - for the post I asked not for. (But thanks all the same).
Dev is telling you that you could get your existing cart retipped for half the price of the Karma/Troika, and don't have to upgrade the arm for now.
I guess it's not much of an upgrade, but it's cheap!
Martin
Per - I just rang saying "help" and it seems they could supply either a Troika or a Karma immediately at the price quoted. I think the old Linn carts come and go fairly regularly. They also turn over a lot of Koetsus.
I've just changed my cartridge from an old Denon 304 to a DV20-X L. Unlike you I like it very much, so please feel free to disregard my views. My TT is LP12/Lingo/Ekos.
I had used a Troika and still have the cartridge. I was very tempted to get it rebuilt as originally it was a fantastic cartridge, and IMO it was better than the Karma - which I heard many times.
I wimped out on a re-build because the stories I heard were so "hit and miss". I was able to listen extensively to cartridges at my dealer and I am very happy with the selection I made.
FWIW I would also suggest you aim to improve the arm first - If you need to replace the DV go for something cheaper and put the rest of the money towards the arm.
I prefer the Ekos to the Aro based predominantly on comparisons with the Troika - although I consider that the Aro probably allows a wider range of compatible cartridges. The Ekos is more user friendly as well, but I could live with either.
Chris
sorry, I was just feeling a bit tetchy because I had to wait half an hour for a service on the computer at work to come back online & I needed to be getting home.
Now then, a Koetsu. Hmm - might be tempted by one myself rather than having them re-tip my ART1 again next time around. I wonder how much?
Sorry again!
Martin
Per I don't think they have e-mail, tel. (from England) is: (0)1372 276 604 - speak to Wyndham Hodgson.
Chris What I should have said about my DV is that I don't like it compared to the Troika it replaced. I also suspect that your DV20X-L is a better cartridge than the DV20X-H that I bought.
JChristophe I'm wavering, I loved my Troika but I do trust the guy I spoke to. Perhaps its simply that Expert can do a better rebuild job on a Karma than on a Troika because of the former's one piece body. If indeed they are the same inside then I guess its fair to ask the same price. Off the shelf I would take a Troika every time.
I asked if they could rebuild them equally well - Yes, 'look after' my Troika in the future - Yes (also various upgrades planned).
Expert prefer the Karma from an engineering point of view and see the 3 point fixing as a sales gimmick; again they said the insides are identical.
I choose Troika because a) pd and others have advised me to, b) I've had one before and was very happy with it, c) know human nature - If I buy a Karma I might always think I should have bought the Troika. The reverse seems much less likely.
Thanks to all
Alex
Originally posted by pd cornelius:
My friends rebuilt Troika is tracking better ... than it did when new
Hmm, this is interesting also - tracking was the area of my own Troika which I was most unhappy about and, of course, concerned about my records.
Fascinating stuff.
My own ART1 has been re-tipped by them a couple of times, and I had not felt it was as good as the original, but it's really doing nicely since my deck was serviced & upgraded recently.
cheers, Martin
