Can my Nait do this....
Posted by: Mr_Sukebe on 12 November 2003
I'm presently using a Nait 5/hicap. It's in used for both music and AV work, powering the front stereo speakers.
I'm thinking of adding a power amp, say a 150 or 200. Whilst trying to do it on the cheap I won't have the cash available to deal with the pre-amp at the same time, so intend to deal with that later.
Here's a question for you.
Is it possible to setup say a Nait 5/200 combo in a straight pre-power combo (I know that bits easy), then put an input back into the Nait 5 to use the power amp for my rear effects channels.
i.e. AV amp > Nait pre amp > Nap 200 (fronts)
AV amp > Nait power amp (rears)
Any thoughts?
