NDAC Based System
Posted by: Flojoe on 31 May 2010
I want a new computer based system based around the NDAC feeding into a 82/HiCap/250.2/Spendor S6e. RipNAS & Sonos look good and easy but what other alternatives should I be thinking about ? Sound quality is very important, but so is ease of use.
Posted on: 31 May 2010 by bigsplice
Im using DAC with Sonos but not enjoying the computer ripping arrangment. RipNAS a very good option but my knowledge is limited on how future proof both the RipNAS and Sonos are. They integrate very well tho i believe!!
Posted on: 31 May 2010 by Flojoe
Thanks bigsplice. Did you come from a Naim CDP. If so, how does the sound quality compare ?
Posted on: 31 May 2010 by Aleg
Sonos is limited to 48 kHz though, so if you would like to play HiRes music like 88.2/96.176.4/192 kHz, then the Sonos isn't going to do it for you.
Why don't you have a look at the upcoming UnitiServe? That will play up to 192 kHz in all kinds of formats.
aleg
Posted on: 31 May 2010 by rich46
aleg
what ever unit you have the number of high res albums are going to limited,and by he looks they are going to be albums you have on cd/lp. a sonos z90 into ndac is extemely good at £240. think we all need to wait before buying
Posted on: 31 May 2010 by themrock
I use Squeezebox Touch.
Sounds really great.
With it you can play High Resolution Flacs.
i have ripnas 1tera £850 /sonos and ive ripped all collection 2800 on flac. ripnas is really well put together and not noisy. cd takes about 4 mins , the ndac is a great sounding hub
Sold CDX2 to pay for DAC and dont regret. Im gonna wait till UnitiServe makes an appearance!
Posted on: 31 May 2010 by Eloise
For ease of use, you could consider a MacBook (£850) plus 1TB USB disk (£80) with M2Tech HiFace (£100) and possibly add Pure Music ($130). To me this would be easier to use - and no harder to setup really - than a Sonos system and will support high resolution (all the way upto 24/192). Add an iPod Touch for full remote control.
Not sure how it compares cost wise to Sonos and RipNAS.
Eloise
P.S. yes you could do similar with Windows PC/Laptop and J.River / Foobar. I'm also not saying the SQ is going to be night and day different - but for not much more than the RipNAS and Sonos (if you includ remote price) it's an alternative.
P.P.S. I'm suggesting a computer as an alternative as it's something you will probably consider further down the road, so worth considering now which route you are going to take.
Posted on: 31 May 2010 by AMA
Flojoe, Logitech Transporter outputs very low jitter (better than Hi-Face and SB3) and has very convenient interface.
Posted on: 31 May 2010 by js
This. Make do for a bit.
Posted on: 31 May 2010 by gav111n
The nDAC re-clocks, so jitter may not be that important in this case when making a choice.
Posted on: 01 June 2010 by Flojoe
Thanks for all the advice. I think I will go for an option that was stand alone, ie no need for the computer to be on for playback. For ripping I,m not sure what the best bet is. I could buy a £ 150 NAS and use i-tunes to rip to it. I could buy a RipNAS at £850 or really push the boat out and get the new Naim UnitiServe at £2k. What advice could the forum members give as to the best way forward for ripping.
Posted on: 01 June 2010 by Andy S
Personally, I use EAC and added the REACT mod. Ripped to single FLAC images with cue sheets and then use xbmc on a linux based PC with optical out as my streamer. If all this is gobbledygook to you, you may be better sticking with itunes or something similar...
As long as you have bit prefect rips (and some systems DON'T give bit perfect if there are issues with the CD) you should be OK with whatever front end you decide to stream with.
Rip once, and do it right!!
Andy, your assumption of your first sentence being gobbledygook to me, was correct. I do want to rip once and do it right, but is there a sound quality difference between the various options of front ends. Sure I can tell the difference between the Naim CDP's as they go up through the price range, but I,m not sure here that as the price increases, so does the sound quality. What are your experiances ?
Posted on: 01 June 2010 by gary1 (US)
Personally, I'd rip to wav, but I'm using the HDX which tags and preserves all of the metadata. Storage should not be an issue at this point. Prices continue to drop and I see no reason to worry about amount of storage required and cost.
From what you've purchased I'd get a Sonos player and use this with your NDAC until you decide on a different front end. According to Paul the Unitiserve are going into production at this time. I'd probably add a Napster or Rhapsody monthly account to your sonos after the 30 day trial ends before ripping anything. Most of your music will be available through the on-line services at a small monthly cost ($12-15), until you decide when you can get a final source. This way if you front end with the Unitiserve, for example, you can then use this to rip your CDs to the NAS and have all of the metadata with the Naim software.
This keeps everything simple, no settings to fuss with, a PNP solution with great results.
If you don't want to go with a Naim solution, then from the "ripping" solutions alot of people like EAC, and if I'm not mistaken JS likes DBpoweramp and of course Wavlab, but the latter requires more work. For anyone at this point who hasn't ripped a CD collection and is even contemplating a Unitiserve, then I'd hold off ripping until the kit is auditioned. This way if you go this route, you can avoid potentially re-ripping the CDs.
Yup, I can tell the differences between the CDPs as well. I'm firmly of the opinion that bits are bits as far as the nDAC is concerned and that it is a great front end leveller as it reclocks the data coming in. See my thread a little further down the page ("Why is the nDAC so cheap?") for the gory details.
Both my mate (CDS2/XPS/252/SC/250/DBLs) and I (CDS1/52/SC/135s/DBLs) replaced our CDPs with PCs streaming into the nDAC. His view was that PC/nDAC/XPS was about equivalent to CDS3/XPS, mine as that the stock nDAC was waaaay better than the CDS1. That and we can browse our CDs from the comfort of the sofa is really cool.
Others seem to hear a difference between front ends - we just can't work out a viable physical method of them actually sounding different (especially if connected via optical) unless the front ends aren't bit perfect (and most are most of the time...). I'd do some dems if you're unconvinced, but I can't tell the difference between my PC as a front end and a USB stick as the front end (everyone seems to say USB is as good as "transports" get).
Your money, your choice at the end of the day. My streamer (which also plays hi-def movie rips too using xbmc) cost me around £300 and some of my time (but I am a geek and I guess a household with 7 PCs and close to 10Terabytes of disc storage in is not the norm Winker).
As to ripping: just google EAC REACT and the threads on hydrogen audio are the place to start looking. There are readmes and you can configure REACT to dump multiple files/formats etc all in one go. If you are PC wary or don't want to mess under the hood, I'd be looking for a more integrated approach from any one of a number of manufacturers.
Posted on: 01 June 2010 by AMA
gav111n, unfortunately I belong to that part of the forum members who clearly hear a difference between different transports when running into nDAC. But it's OK if you don't hear it -- and you will find a lot of supporters here as well!
Andy for me the cheapest option would be to buy a NAS then rip to it using my laptop. However I have read that these DVD/CD drives are not neccesarily the best. Are you saying that in your opinion, providing the data stream can be read without error, stored and streamed to the nDAC, there is no reason why it should sound any different to data ripped froma specialist drive. I dont want to do this cheap, I want to do whats best, but I would rather spend money elsewhere in the system ( XPS for nDAC ) then on fancy drives.
Posted on: 01 June 2010 by gav111n
Hi AMA,
You get me wrong, I am with you on this point. I too am in the ‘you can hear a difference between transports into the nDAC’ camp. However we are now in a ‘post-why is the nDAC so cheap-world’ Winker where no one seems to know why they sound different.
What I am trying to point out is that the nDAC is designed to eliminate or massively reduce jitter, so using jitter specifications to guide your transport choice (as you suggest) may not be so clever. Best to listen to a few choices if possible and choose on your perceived SQ.
Posted on: 01 June 2010 by bigsplice
Im finding great success ripping cd's to NAS via windows 7 laptop running DBpoweramp (£30) and playing through Sonos into Naim DAC. Hope this helps.
Thanks. I have windows XP, do you think DBpoweramp will work with this ? Do you think the make/model of NAS makes any difference. Sorry for all the questions, I'm bit new to this.
That's my belief - yes. Using a program like EAC with most (all??) modern day DVD drives should produce an accurate rip as if any errors are detected (EAC reads at the real low level) data is reread until a match is obtained over a number of reads. I'm pretty confident my rips are accurate and once on a PC drive somewhere, bits definitely are bits on a PC drive.
EAC is also free Smile
Good choice IMHO Smile
Andy, I've been ripping CD's using i-tunes set to WAV. What advantages will EAC give me ?
Posted on: 01 June 2010 by Eloise
With a perfectly read CD, there is (to my mind anyway) no difference between ripping using iTunes and using EAC (or equivilent other programmes).
The difference comes because there is no feedback with iTunes as to how effectively the rip has been made, and if there are errors iTunes interpolation may be less effective than others. EAC (and others) use a system called SecureRIP which compares the results of your own rip with others that have been made by other people. That gives you a level of confidence that your CD has been correctly ripped.
Eloise
Posted on: 01 June 2010 by pcstockton
Except for all of the reason I use EAC and not iTunes.
1) Log File
How would you know you errors without one?
2)Correctable drive offset.
Why not?
3) Cacheless Secure Mode.
Proper ripping.
4) Cue Files
Creates cue files for many uses including using with a memory player or perfect copy burning of a CD.
5) Pre Gap tracks!
Enough albums have pregap tracks to warrant wanting this feature.
and more.....
-Patrick
