UnitiServe - Backup & Restore
Posted by: Joe66 on 01 November 2010
UnitiServe - Users,
There is a short description in the manual how a backup of an UnitiServe should be made, but there are no remarks regarding restore procedure etc...
Before I do the whole backup thing I want to be sure that restore works, so I´d like to know if some experiences are out there...
Has someone done already backup & restore? Are there some recommendations from experienced UnitiServe-Users?
Best regards!
Josef
Posted on: 01 November 2010 by Phil Harris
If you have backed up the MQ,LQ and HQ folders to a separate network share then you can simply mount that share as a store and copy the music back...
Phil
Posted on: 01 November 2010 by Basically Sound
Phil
Did this last week for a customer whose Serve started playing up. Backed up his original Serve to NAS, then made the NAS a share, then into a store, then, using the "Move Music" function, transferred the backup data on to a new Serve.
All sorted now, BTW Phil.
Posted on: 03 November 2010 by Joe66
Thank you, gentlemen!
Does backup mean with a typical backup software or is a 100% mirror copy ( eg like the windows command line tool robocopy does) also ok?
I will test that, so will do the following now:
1. - run robocopy tool by a time triggered batch file to make a 100% mirror of MQ folder (there are all my CD rips) to a network share
2. - delete one subfolder ( = one CD rip) on the UnitiServe via UnitiServe menu
3. - try to mount the network share
4. - copy back the deleted MQ subfolder to the UnitiServe via UnitiServe menu from the network share
If this works I´m sure to have a proper backup & restore procedure...
BTW, I really love my nice little black brick!
