Great Citroen Advert...........
Posted by: long-time-dead on 10 May 2005
Posted on: 10 May 2005 by Berlin Fritz
Der Shove Ho
(said fast innit)
Posted on: 10 May 2005 by Martin D
strange, i posted the same thing about a week ago and its know where to be found, unless some one found it offensive (again)
May we ?
nah jokin about the cat video, lets bring that one back again
But the one i started was called
something like great citreon advert..........not
but its vanished
but its vanished
I bought three fresh Brazilian Limes yesterday for 49 Cents, they're far nicer, innit
bugger - typo
Posted on: 10 May 2005 by J.N.
Martin;
Your original post with a link to the Citroen advert has indeed disappeared.
It was there, because I sent it onto a friend who has a Citroen Picasso. I can't remember anything offensive about your post.
John.
John.
weird - we should be told!
cant find it in my "see your posts" thingy either, what else goes missing around here for no reason?
Posted on: 11 May 2005 by Martin D
bump............
Adam can you comment?
Posted on: 11 May 2005 by Harry Street
This is a funny forum. First I disappear from the Corner only to reappear in the padded cell. Then when I reply to responses, my response disappears altogether. Gone without a trace or comment. I suspect it is Adam. His name sake was kicked out of a pretty good situation because he screwed up. He doesn't want to take any chances on screwing up this time around.
Posted on: 12 May 2005 by Adam Meredith
You were moved to the Padded Cell as this thread, from a new member, had quickly deteriorated into a slagging match between you and kuma.
In addition, although not the reason for the move, discussion of banned members is normally frowned upon in other forums and is will be discouraged here.
I occasionally remove posts which link to other sites where "mobile code" is required to be enabled. I cannot view these at home without going through a de-security procedure.
As a result some of these links will be removed as a precaution.
As I do most moderation from home I am not in a position to send out e-mails without using my home address.
Posted on: 12 May 2005 by Martin D
that makes perfect sense, thanks for the answer
