questions on CDX2
Posted by: kuma on 02 November 2003
Does anyone know which chip set and transport CDX2 uses?
Does this CD player upsample?
Posted on: 04 November 2003 by Jason Milner
Hi kuma
This is the closest I could get to answering your questions, from the main website...
Any help?
J
Both the transport and chipset have been upgraded for the CDX2. The HDCD decoder/digital filter is only activated when playing encoded discs. Eight-times over sampled data is then sent to two (one per channel) Burr Brown PCM mono D/A converters. A separate, fully optimised master clock controls all main digital functions, and the clock configuration and layout are engineered to minimise jitter. A seven-pole analogue filter follows the DAC to remove spurious noise.
Any help?
J
Posted on: 04 November 2003 by kuma
hehe yeah. i read that. Naim is not very forthcoming with their technical bits.
All I could manage to find is that it uses 24/96 Burr Brown chip set and Phillips' front loader version of VAM 1250 transport.
Posted on: 05 November 2003 by Jason Milner
Well I suppose I could take mine apart to see what bits are inside, but then again, the chances of it ever working afterwards aren't far from zero, so I'll have to pass
If no one else can help here maybe an e-mail to Naim direct might help (having said that I have no idea on their policy re such direct requests - they do keep an eye on the forum though, so maybe they'll be able to dig out the full techy details for you here?)
As an afterthought, despite exposing my appalling lack of technical knowledge re chip sets & transports, I can confirm one thing... it sure sounds good
Posted on: 05 November 2003 by andy c
Ditto what Jason says about the sound of the CDX2.
Kuma, why do you need to know the answers to the questions you pose?
Posted on: 05 November 2003 by kuma
ohhh.. just out of curiosity.
Altho, Phillips transports generally sound nice, I never had a good luck with em. Let's see how long this one last.
I usually don't pay attention to any technical bits at all. But I don't mind finding out more about the gear that I like.
And CDX2 is one of those that interests me.
Posted on: 05 November 2003 by joe90
Its a Philips transport only in name (Naim?).
Naim have used those transports for years and they last fine, and, as far as I can glean, are easy to fix cause of the way Naim use them (tray being manual and all that).
Upsample? No. Thankfully Naim don't go in for that. I have listened to upsamplers and SACD and DVD-A(trocious) and they're no magic wand.
The 16-bit CD still sounds better to me...
Joe90
Joe90
Posted on: 05 November 2003 by Geoff P
Won't help but here are some photos I "had"to take.
GEOFFP
GEOFFP
AND
FINALLY
Really? I'm gonna show my total ignorance here, but with 24/96 chipset, i'd think that's automaticaly upsampled. But you are right in that CDX2 does not sound like upsampling cd players. ( they usualy have this strange *air* about 'em )
ditto on the SACD playback, but I had a good demo on recent Maridian DVD player ( with 6 watts SET amp! ) in two channel mode that was hell of lot more convincing than any mega$$ SACD players I have heard. ( i get killed saying this amongst hi=res. zealots
And yeah.. I don't buy *bits game*. I've heard just too many so-so 24/96 or 24/192 cd players/DACs.
I still use almost 5 year old 20 bit Ultranalogue cd player and surprisingly it's still hanging in there.
woooo. Audio Porn.
how many screws you had to unscrew to take the cover off?
FIVE! The four "feet" and one other big screw, then the whole thing slides out.
The DAC's are 24 bit but it does not follow that they run at 96KHz. There is no upsampling going on as far as I know.
I agree that upsampling players sound "airy" butthat translates to easily into bright and tinny in my experience.
I have haerd nothing non-naim that could replace my CDX2.
regards
GEOFFP
regards
GEOFFP
Posted on: 05 November 2003 by Martin D
Phono out's crikey what would JV say !
Martin
Martin
FIVE? THAT'S IT? FIVE????!!
I've flipped mine over and looked but wasn't sure which screws to take off, so left it alone.
Interesting if Naim doesn't do upsampling thing. So far filterless/nonupsampling machines have the same sort of agility as Naim player. Not all upsampling players don't sound atmospheric. Krell player I continue to use for example, is saved by sheer bass weight and authority but slower and really laid back next to CDX2.
Posted on: 05 November 2003 by Dawie
The pictures spoiled it ! It looks almost "commonly electronic".
I much prefered the comfort zone that I was in - there's magic and trickery in there, that's why it sounds sooo good.
Posted on: 06 November 2003 by Geoff P
Kuma
Yes. There is one allen key bolt which has a barbed washer below it (visible in the case indent under the bolt head) and then the are the allen screws holding the four feet.
Three comments:
1) I did NOT turn the CDX2 upside down with the transit bolt removed. I put the transit bolt back in first and then turned it over to remove the screws. Then I flipped it back right side up and slid one corner over the dge of the table to remove the transit bolt.(reverse of that to reassemble)
2) Naim would probably be upset at this procedure so I must add if you do open the CDX2 up it is entirely at your own risk!!
3) There has been comment to the effect that the screws holding the feet are torqued to a fixed setting which gives optimum sound, so again undoing them is at your own risk on the sound side aswell!
Dawie
Too true! I just had to check what the 2.3K has bought. But of course I realise now that though you could probably price the hardware you can't price the magic.
regards
GEOFFP
Posted on: 06 November 2003 by Mario
Geoff, don't you also have to take off the 3 allen bolts in the middle, near the front?
Mario.
Mario.
NO. They hold the "Swing" mounting for the CD tray into the subchassis which pulls out as seen in the photograph and should NOT be undone.
GUYS!!
Please, please tell me I have NOTstarted a rash of dis-assembling!
I am not going to be responsible for anybody who does this !
All completely at your own risk.OK?
regards
GEOFFP
Geoff, no you have not started a wave of cd player dis-assembly. Your excellent photos negate any need for that. I just seem to recall the pic upgrade manual for the cdx2 saying to remove these three screws. I'm sure that I removed them and no transport fell out! Any way if your player came appart without removing them, that must be right. Maybe my memory is playing up.
Mario.
Mario.
Posted on: 06 November 2003 by kuma
You got to be joking.
It sounds too fantastic as mains cables make difference.
