loud "crack"
Posted by: jason.g on 01 September 2003
i'm using a naim 62/90 set up and sincing owning it (second hand) it has made a loud crack noise when turning on and off, even with the volume fully turned down. can i rectify this easily?
what was the best thing before sliced bread?
Posted on: 01 September 2003 by David Stewart
The bread knife Smile
Posted on: 01 September 2003 by garyi
Jason, this is perfectly normal, something to do with the capacitors.
One question, are you always turning it on and off? Its best left on all the time.
Posted on: 01 September 2003 by NB
Jason,
There is a very easy way of stopping this happening:-
"Don't turn your amp off"
and by doing that you will also benefit froman improvement in the sound quality.
NB
Posted on: 01 September 2003 by prowla
The above are correct:
(a) Naim kit makes a pop through the speakers when you turn it on/off.
(b) It is generally accepted that you don't switch Naim kit off.
Paul Rowlands
Posted on: 01 September 2003 by Paul Ranson
Is a 'loud crack' normal? I'd expect more of a soft thump.
How about if you disconnect the pre and power up? If that is quiet it implies the muting relay in the pre is faulty. In which case getting it fixed or leaving the combo powered up is appropriate.
If the power amp is 'cracking' it probably needs a service.
Paul
[This message was edited by Paul Ranson on MONDAY 01 September 2003 at 20:59.]
The OP says '62/90' which implies the pre is supplied from the power amp.
Paul
