'Kontak' electrical contact cleaner
Posted by: Andrew L. Weekes on 29 March 2001
It's apparently a contact cleaner developed for military applications, and does not leave any residue on the surfaces once cleaned. It will remove all traces of oxidization and contamination from the cleaned surface.
I'm a very strong believer in system contact cleanliness, and every part of my system, from the fuse in the consumer unit, through to the connections in the cartridge usually gets a thorough clean with duraglit / isopropyl alcohol as applicable every 3-6 months.
Interim husbandry usually involves the unplugging and remaking of connections and a quick polish of mains plugs. There is always a noticeable improvment as a result of this, and the instigating reason for an hour of uncomfortable scrabbling on hands and knees is usually because the system is not quite 'right'.
Anyway, having received my bottle of Kontak last night, I set about cleaning the system from head to toe.
Several mains plugs, fuses, interconnects, speaker plugs / sockets and cartridge connections (followed by an hour warmup) later I settled down for a listen. This stuff really works, if the disgusting amounts of grime left on several pipe cleaners and cotton buds is anything to go by.
The sound of the system is noticeably cleaner, and subtle rythmic elements and low level detail are better portrayed. It has a similar effect to the normal housekeeping, whereby a veil or grainy layer to the sound seems to disappear, but it takes it to a much higher level. The improvements are definitely musical, not just Hi-Fi.
All in all not bad for £15, and judging by the amount I used (very little), it should give me a couple of years cleaning.
The solution is now in a single bottle (the previous incarnation was a two part solution, supplied in seperate bottles) and is far less volatile than the previously available versions, so evaporation is less of an issue.
Anyone else have any views?
Andy.
Andrew L. Weekes
alweekes@audiophile.com
