Sound advice!
Posted by: Diccus62 on 02 November 2008
I have a Samsung 37" LCD TV (LE37R67BD). I was thinking about linking it up to my NAC 72. If it is that simple what leads would I need? On the back of the 72 I only have 2 tape inputs left unused, would they be adequate.
Any advice of a simple nature would be appreciated
Ta
Diccus Smile
Posted on: 02 November 2008 by davereay
Buy an RCA to Din from Chord or flashback sales and plug it into your tape input, not sure about the input levels but I think they will be okay, you may find some reverse attenuators will be necessary to avoid loud volumes at low listening levels. I have my DVD and TV routed in the same way through my Nait and is great for listening to music programmes or films. (search e-bay for attenuators from goldenjacks). Dave
Posted on: 02 November 2008 by Diccus62
thanks Dave, i'll check it out. Do I need a 4 Pin Ring Locking DIN Plug - 2 Phono/RCA Plugs Performance Cable?
No probs, yes 4 pin, I guess with lock ring, you will have to check the back of your amp to be certain. The flashback sales website shows the different types.
Dave
Posted on: 03 November 2008 by Diccus62
yeah defo locking ring - thanks again
Diccus
