Indoor ariel for DAB/FM module of n-vi
Posted by: meaculpa on 08 December 2007
I want to uset he DAB/FM module of my n-vi, but cannot have any more wall sockets, cable runs or channeling to allow me to use an external or loft ariel!
My dealer has suggested I try a D&M indoor DAB antenna, whish I have, but still no joy on DAB or FM. With DAB I get no signal, and FM between 6-18% on some channels, but not enough to get a station.
Does anybody have any other suggestions, or am I not really going to be able to solve this one without a loft, or external ariel.
Thanks in advance.
Posted on: 10 December 2007 by james n
I take it you dont have a feed from a TV antenna or any coax at all coming into the room where your n-Vi is ?
rgds
James
Posted on: 14 December 2007 by AV@naim
TBH, using a TV antenna for DAB is not ideal, the range of reception for TV aerial is optimum around 420-900Mhz.
DAB runs from 170-240Mhz, so the gain would be very poor...
Posted on: 15 December 2007 by james n
Sorry - should have been more clear. I didnt recommend he use a TV antenna - i asked if there was a feed from a TV antenna. If so he could add a diplexer either at a loft antenna or chimney without having to add an extra cable just for the DAB antenna - works for me.
James
PS - How do i get updated firware for my n-Vi. My local dealer suggested i email you first ?
Posted on: 15 December 2007 by AV@naim
Your dealer should contact us if they don't know how to obtain the firmware.
Cheers - i'll give them a bell Monday.
Posted on: 02 January 2008 by gloop
Hi. I'm in a similar situation - have n-Vi, but don't have easy access to an external aerial. What would be your recommended options in this case?
There is actually a roof aerial socket in the room where I have the unit, but I have connected this with coaxial cable and it seems to do a less good job than the old TV antenna that I have.
Your thoughts appreciated. Thank you.
Posted on: 03 January 2008 by james n
Gloop - Where does the roof aerial socket in the room connect to ?
James
Posted on: 08 January 2008 by Former member
You need a very very good ariel to make the n/vi FM DAB tuner work.
A indoor will not work at all well unless you are in a very good signal area.
I Never got mine to work, and i have a good one.
Every other tuner i have had worked great .
But not the one in the n/vi.
Munch
Posted on: 09 January 2008 by gloop
james n thanks for your interest. The roof aerial socket does indeed connect to a roof aerial, though I'm pretty sure the connection is broken somewhere. Problem is, we're renting at present, so can't replace anything like this...
Suggestions??
