Hi-Line for AV?
Posted by: Billy Rubin on 07 April 2008
Can a regular DIN-DIN version be used as a replacement for the interconnect between an AV2 and the pre-amp?
BR
Posted on: 07 April 2008 by Former member
I think you will find it can only be used between a cdp or dvd player into a pre.
Munch
Posted on: 07 April 2008 by David Dever
Will work with n-Vi (playback only), and can be adjusted by your dealer or distributor for AV use (playback only–no feed from preamp to AV processor)–no soldering required!
Posted on: 07 April 2008 by Billy Rubin
OK - Thanks for the speedy replies.
BR
