Sort of an upgrade type question
Posted by: Kevin-W on 10 April 2003
OK chaps
I have £500 to spend. £100 or so of that is going on getting the LP12 serviced (it hasn't been looked at for nearly 6 years). The weak link in my analogue front end is tthe cartridge (K9). I have a pair of 323 boards, so I could upgrade to a £300-£400 MC cartidge. Any suggestions for an audition?
Kevin
Posted on: 10 April 2003 by J.N.
The number of the beast
Kevin;
The Dynavector range seems to take some beating. I use a DV 10x4 in an Ittok (around £200) which is a high output moving coil; so works into m.m. boards/Stageline.
I'm delighted with it.
(I think the garlic worked) See below.
Posted on: 11 April 2003 by David Stewart
Ditto here, I recently replaced my ageing K9 in an Ittok with a 10x4 and the improvement was remarkable, much more engaging presentation.
Dynavector have now introduced the 10x5 to replace the 10x4 - it is a bit more pricey. If you can afford more the 20X is even better.
Posted on: 12 April 2003 by NB
Kevin,
There is the ortofon MC15 super which takes some beating. Its only £140 which leaves room for improvement elsewhere.
Posted on: 12 April 2003 by Mekon
Have any of you done an A/B of the 10X5 (or 4II) vs the Adikt?
Posted on: 12 April 2003 by syd
I'll second Kevin on the Ortofon MC15 super as thats what I'm using at the moment on my LP12/Ittok combo. Though if you can stretch your budget the Linn Klyde I had previously was a lot better, at least until I broke of the cantilever
. As soon as funds are at a healthier state I'll probably buy another.
Yours in Music
Syd
