Thinking of buying an nVi, help
Posted by: cafez27 on 24 March 2009
Hi
I have a need to consolidate my av reciever and dvd player into one box to create space, get rid of a cabinet, for my 2 channel system.
I have an LP12 as my front end and all Naim amplification including a SL.
I am thinking of getting an nVi and Sky HD along with a new panel and putting both on my Fraim which is to the side of the room.
Two questions, is it easy to convert the DVI output to HDMI with a custom cable perhaps from Chord, and given the picture is 576p does/has anyone had any problems using with an HD panel?
Many thanks
Jez
Posted on: 26 March 2009 by john R1
have read of some problems with the handshaking using dvi to hdmi from the n-vi, having said that i demoed my n-vi via hdmi and component into panny 428 plasma, i found the component run smoother in my opinion, i run it via component into my fujitsu plasma with very good results,
Posted on: 26 March 2009 by gone
no problems here - I've been using quite a long DVI-HDMI cable (5 metres-ish) to a Pioneer 43" plasma and the picture's great - even though it's SD, the quality rivals some HD pictures I've seen, even without upscaling (sore point).
Don't forget that the DVI output is just that - video - no audio of course, but I guess you'll handle that through the 2 channel system
Hope that helps
John
Posted on: 27 March 2009 by cafez27
Many thanks all thats all needed much appreciated
Jez
