Is a Naim system intended to be set up this way?
Posted by: JeremyB on 20 March 2003
I decided not to move but to buy the house I'm renting. So I'm free to make holes, install a second consumer unit and any other measures in the listening room.
Then it occurred to me - my listening room is by chance adjacent to the garage. Which means that the PS and NAP135s could be in the garage with only the Bundy and SNAIC going through the wall behind the preamp and the speaker cables through the wall in the corner. Also I won't hear the transformers buzzing. Best of all, the power leads could be wired directly into the 100A consumer unit!
Has anyone tried this? What is the best way to fill the holes around the leads?
From the position of the connectors on the preamp/power supply this option doesn't appear to be accidental.
