J*** FM testing on Sky Digital
Posted by: Michael on 29 April 2002
For your information the London Version of Jazz FM is now testing on Sky Digital and therefore available nationwide. It does not yet appear in the Electronic Programme Guide.
To receive it go to the Services Menu
Press 4 System Setup
Press 4 Add Channels
Enter Frequency 12.324
Polarisation V
Symbol rate 27500
FEC 2/3
Find channels
When the list of channels appears for that frequency press the green button to go to the second page.
Scroll down to jfm and press the yellow button to select it.
Then press select again and use backup to get back out of the menu system.
To listen to Jazz FM ..if you have done everything correctly ...press services... other channels and you should see jfm listed ...highlight it and press select.
Hook your Sky Digibox to your Naim if you haven't already and away you go. ( Or of course listen through your TV!!)
Happy listening
