Advice on configuring an IXO
Posted by: Bob McC on 04 October 2002
I've got a NAP 250, NAP 160, IXO and IBLs. I want to run active. Is it possible to configure the IXO/cabling so that the 250 runs bass and the 160 runs treble and if so does anyone out there know how. All advice gratefully received!
Posted on: 04 October 2002 by David Tribe
Bob,
The IXO is designed to use two amps of the same type. The signal is separated into left and right channels. Each Channel has a bass and a treble output. You can get the manual from the main website. The IXO is covered on Pp. 14-15.
Hope this helps.
DCT
Posted on: 05 October 2002 by Jeremy Roebuck
I'd really advise you look for another 250, I got my second 250 on ebay for £720 and run both with an IXO, one left & one right, sounds peachy
