Home-made Naim icon
Posted by: Henry Cosker on 30 April 2001
Here's a reasonable home-made Naim icon for your desktop shortcut to the Naim conference site!
Henry
Posted on: 30 April 2001 by David Dever
...courtesy the NANA Mac desktop.
Dave Dever, NANA
Posted on: 01 May 2001 by Jay
Henry, how do you set-up a desktop short-cut to the forum?
Jay
[This message was edited by Jay on TUESDAY 01 May 2001 at 10:48.]
Posted on: 01 May 2001 by Henry Cosker
Jay
>>how do you set-up a desktop short-cut to the forum?<<
Assuming you have the forum as a favorite, in Win95/98 go to the favorites list at the Start button, right-click the Naim one and select 'Create shortcut'. Drag the new shortcut, which will have a [2] after the name, onto the desktop, where it will have a standard Windows icon.
To change the icon right-click on the new shortcut, select 'Properties', press the 'Change Icon' button, and browse your way to where you downloaded the new icon. Select it and 'Apply'.
Hope this helps.
Henry
Posted on: 01 May 2001 by Martin Payne
Well, possibly.
This will be my first attempt at uploading to the forum, so bear with me.
cheers, Martin
Strewth, it worked....
