Nait 5 Problem
Posted by: alex95 on 22 October 2003
When I connected my Nakamichi tape deck to my Nait 5 using the TAPE input, nothing happened, when I selected TUNER I could listen, but my SACD player is connected to TUNER. Also when the tape deck is connected to any input and I want to listen to CD or SACD the sound is muted compared to when the tape deck is disconnected.
Anyone able to shed some light on this.
Spence
Posted on: 22 October 2003 by Manu
Look like your tape input/output plugs are reversed.
Emmanuel
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
Posted on: 22 October 2003 by Justin
I have a similar problem. Whenever I plug my TV/DVD player into the tape input, two things happen. First, the volume on that input is much lower. I have checked the input sensitivity levels, and everything is normal. The other issue is that whether or not that input is selected, as long as I have something plugged into it, I get huge amounts of hum and hiss through the speakers. You can hear it from across the room. As soon as I unplug from that input (again, whether selected or not) the hum goes away.
These are little gremlens I'm finding with the nait5. I wonder if things improve if I move it all away from the TV.
Judd
For the hum from the TV, it can come from the Cable TV input. Use a ground isolator, available at Radio Shack for 10$. Or ground the outer shell of the F plug at the TV cable input.
To be sure, just disconnect the coax cable at the TV or at the wall plate.
Emmanuel
Posted on: 22 October 2003 by Lightkeeper
Alex,
change your interconnect cable which you are using for connecting Nakam deck, or reconnect leads which comes to din connector in a right way.
Ozren
Posted on: 23 October 2003 by domfjbrown
Emmanuel - that earth loop device doesn't always work - it didn't solve (admittedly VERY low level) "treble click" hum from my AV amp - whether the telly was connected to the aerial or not. In fact - the ground loop isolator actually made the hum FAR worse! A waste of £25 if ever I saw it....
So results may well vary.
__________________________
Make your choice, adventurous Stranger;
Strike the bell and bide the danger
Or wonder, till it drives you mad,
What would have followed if you had.
