Multiroom Usage for Naim equipment
Posted by: rael on 06 August 2003
I know I have touched on this subject in a previous thread, however I am very interested to know the full range of options available to use naim equipment to best effect between 2 adjacent rooms, where there is a route for cables.
My system will be CDXII/XPS2/252/300/SCII/AV2/NAPV145/NAP150, one room will be the main room used for music and AV and the secondary room for music only. I would if possible like to utilise the NAC252/300 in both rooms as opposed to adding a substandard integrated amp in the secondary room, with the result of substandard sound quality.
I tend to use both rooms an equal amount for music, the secondary room more at night as it is internal to the house, so protection from the neighbours.
Note : I would not necessarily need to use the system in both rooms simultaneously, although it would be preferable as I may need to use AV and music system at the same time.
The options I can think of are as follows -
1/ use a switch between the pairs of speakers ( Not Recommended due to likely degredation in sound )
2/ Buy an integrated amplifier such as the Nait05 and connect to the Record output of the 252 ??
I would be interested to hear anyone who has had a simliar dilemma.
Cheers Rael
Cheers Rael
