Prefix effect
Posted by: Adolfo Aguiar on 03 September 2001
What sort of improvement should I expect with Prefix?
Would there be any improvement if Prefix was powered by a lesser PS (i.e. FlatCap 2) or is a Hi-Cap the minimum required?
The Prefix makes a big difference in my LP12, even when powered by the secondary output of my Flatcap2. It's a superb phono stage, and removing the arm cable seems to make a lot of difference.
I'm currently using a modified dual-railed, recapped SNAPS, which is even better, so improving the PSU makes quite a difference.
I'm certain the Prefix powered by a Flatcap2 will outperform the 72 / Hicap. Removing the phono boards from the 72 may have a subtle(?) effect too, reducing the load on the Hicap.
Andy.
Nigel
Regards.
OK Andrew so now I'm really confused I have a prefix powered by my 52 and an old Lingo with the filter mod (thanks for that one ).
You're welcome!
Now I see something else in the Earth loop discussions that I may be able to do more in the quest for excellence . Do I need the Conn401/e or should I considered my safe from the evils of the Lingo? Please advise a very confused fellow. My lead from the Lingo is well away from everything else so I think that RF coupling can be ignored.
From the perspective of audio, the Con401/E or it's absence makes no difference if you have a Prefix. The Conn401/E would just earth the chassis of the LP12, not make any connection to the earth lead that comes from the Prefix.
From a static drain point of view it could be useful if you're experiencing problems. I'm not, but I shall probably add a DIY conn 401/E to my LP12 anyway.
You do need a connection between mains and signal earth somewhere in the system. If you don't have a Naim CDP or any other source that makes this connection a wire from mains earth to the tag on the 52 would suffice.
Hope this makes sense.
Andy.
Thank you for reassuring me. I have a CDS-II so signal to earth. I would be interested to know how you get on with the home-made lead though.
Nigel
