What is the size of the spur for the average mains plug at home?
Posted by: Consciousmess on 08 March 2009
Hi,
I had to ask this question as I'm soon to have a separate spur fitted, and my 3 powerlines will all be flush with the wall (as opposed to two of them being on a multiplug).
I believe the analogy of a water pipe can be used, as I will be going to 10mm spur and potentially have a 10mm cable for each plug.
But in a typical double mains socket, what is the thickness of the wire that connects this to the consumer unit (e.g. under the stairs)?
Many thanks,
Jon
Posted on: 08 March 2009 by Analogue
I believe it's 2.5mm
Posted on: 08 March 2009 by DaveBk
I agree, 2.5mm is used for most domestic ring mains, spurs and radials.
Posted on: 08 March 2009 by gone
Originally posted by Consciousmess:
I had to ask this question as I'm soon to have a separate spur fitted, .......
Don't forget - please report back with your findings!
John
