New Uniti Owner (with some questions............)
Posted by: divuk83 on 19 January 2010
Ordered a Uniti the other day so I have a few questions about it.
1. The setting to set the size of the speakers "Large+Sub / Large / Small+Sub" is that some kind of low pass filter or something? At the moment I have my sub (REL Stampede) connected to the F connecters at the back of the speakers (n-Sats). Should I set it to "Large" or is it going to be any better connecting the sub up the the sub out on the Uniti?
2. This whole computer audio thingy, what software is good to rip flac files and the get a upnp thingy setup? I'm using windows 7 64bit and would prefer to not have to use itunes.
3. I have a spare CD ROM drive sitting about, is that going to be any better than a Bluray drive for ripping or will it not matter?
I'm sure there are many more questions but that will do me for now.
Dave
Posted on: 22 January 2010 by divuk83
I think I have sorted question 2 as I can use Foobar. If anyone has an answer to question 1 I would be greatful.
Another question;
4. Are there or will there be any iphone/touch apps for remote controling the Uniti?
Dave
Posted on: 22 January 2010 by garyi
There already is Dave (Well for the upnp bit anyhow) and its called plug player, but of course you need itunes for that.
I do wonder at peoples reticence with itunes, its just software.
