Cleaning CD's
Posted by: Davidmanne on 22 September 2003
About 10 years ago, I purchased the Mozart piano Sonatas played by Mitsuko Uchida. I used to play them daily. However, about 3 years ago we did a major renovation and the CD's were stored, then taken over by my children. They've gone away on holiday, so I repossessed them, only to find them quite filthy.
How are you meant to clean them?
Thanks, in anticipation
Posted on: 22 September 2003 by Thomas K
David,
I've heard of people successfully cleaning CDs with water and a dab of washing-up liquid, then rinsing with destilated water and drying with a "soft, lint-free cloth".
Thomas
Posted on: 22 September 2003 by Jez Quigley
I use 'Crystal-Disc' from David Powell Distribution ltd, 182b Park Avenue, Park Royal, London, NW10 7KH. It's available from some record shops.
I find it makes even really bad discs playable again eg those borrowed from your local library. It has only failed me on one such disc and that had a really bad gouge in it. It cost about £3 for 20ml but you only need a tiny amount for each disc so it lasts for ages.
"Seek first to understand, then to be understood"
Posted on: 22 September 2003 by j8hn
I clean mine in the bathroom using liquid hand soap.
Run a basin of clen lukewarm water dunk the cd in it squirt a dab of soap on your thumb work it from the centre out over the cd whilst also rotating it. Do several then run a bowl of clean lukewarm water repeat the thumb action this time to rinse the discsl Lay each disk on a clean fluffy towel, then gently blot them dry starting with the hole and outer edge where the water tends to collect.
Haven't found an easier or cheaper method [have tried Finyl and the Brady stuff].
Posted on: 23 September 2003 by J.N.
Hi David
Disposable moistened spectacle wipes work for me.
Wipe in straight lines from centre to edge.
Good luck.
Posted on: 24 September 2003 by Davidmanne
Thanks for all your advice.
In general, you've all suggested simple, low cost approaches that work.
I like that!!
