Posted on: 08 June 2003 by Martin Payne
NO!
I know someone who used the wrong burndy with either a 52 or SNAXO (can't remember which). The unit had to go back to Naim to have some fairly major surgery before it worked again.
cheers, Martin
E-mail:- MartinPayne at Dial.Pipex.com
Posted on: 09 June 2003 by effinity
Ah, you're here Neil, I guess that answers that question!
Martin is absolutely bang on (as usual!)
Thanks for SBL advice!
Also had reply from Richard Dane to say the two are completely different and cannot be swapped around.
Steve
