Sbl`s and set up
Posted by: Big Ears on 18 April 2002
Hi all
recieved my Sbl`s on tuesday but unfortunately the instructions were not in the box so i can`t set them up properly but i have just ordered the gasket kit to seal them.
I have ordered a set of instructions from naim so they should arrive soon. Does anyone have any advice regarding the positioning to the wall and on toe in etc.
Regards Gary
Posted on: 18 April 2002 by neil w
give me a e mail for contact numbers and ill lend you my instructions i also have spare sealant
i live near beamish
Posted on: 18 April 2002 by garyi
http://homepage.mac.com/garethirwin/rebuildSBLs.pdf
That will give you a fair idea I think.
Posted on: 18 April 2002 by J.N.
I like them hard up against the wall with a small amount of 'toe in' but it's a personal taste thing, really.
Experiment with positioning; THEN rebuild, seal and leave 'em be.
Posted on: 19 April 2002 by garyi
Trouble with that JN is that you can't get even the slightest idea of how they will sound without the seal in.
I guess if you are in the position with SBLs already set up then experiement, then take apart then rebuild.
Perhaps I should make that clearer.
Posted on: 20 April 2002 by J.N.
and you were talking about re-sealing them.
You're only going to find out where they sound right to you in your room, by trial and error.
I have no faith whatever in mathematical formulae, computer programs etc: to come up with the answer.
You, and your room are far too complicated!
