ipad spotify remote airfoil
Posted by: sjw on 13 September 2010
I wondered if anyone could help please
will an ipad work A)with the REMOTE app to control playback of itunes
B)can i use the ipad with spotify and airfoil to play spotify over the wifi and thro my naim
many thanks stephen
Posted on: 13 September 2010 by pcstockton
yes and yes.
For the latter you will need a mini jack-to-RCA (or DIN). You will go out of the iPad from the earphone output and use the iPad's internal DAC.
Dont expect this to sound very good.
But if you are only streaming lossy music anyway it probably wont matter.
-Patrick
Posted on: 13 September 2010 by sjw
wont the music from spotify go over the apple wifi via the airfoil?
i don't want to use the jack socket
thanks
Posted on: 13 September 2010 by jlarsson
only the airfoil speakers app is available for the ipad, no?
this means you can run spotify on a macbook and play it over the ipad speakers. over wifi.
there are a few USB-DAC:s that work with the iPad (and many that do not work) if you have the camera connection kit. but then we are back in wire-land again.
Posted on: 14 September 2010 by Eloise
A) Yes, you can use the Apple Remote app on an iPad to control iTunes. However the application is "designed for iPhone" and is just zoomed for the iPad so graphics, etc. can be quite blocky. Also check out yTracks app for the iPad.
B) The iPad can't sent it's own music via Airfoil or direct via WiFi to an AirPort Express / Apple TV. If you want to feed music to a HiFi from an iPad you have a few options:
  • connect via analogue either via Mini-Jack / Headphone socked or (slightly better) via Dock connector.
  • use the Camera Connection kit to connect via USB to a compatible DAC (needs to support 16/44.1).
  • use Bluetooth to connect to a DAC such as Chord's GEM - either direct or via APT-X dongle.
  • use a proprietary wireless technology to connect to a DAC such Arcam's rDAC (wireless coming soon).
  • wait for the iOS 4.2 update (due around November) which will allow AirPlay from iOS devices as well as iTune; to AirPort Express / (new) Apple TV / third-party AirPlay devices. The AirPort Express / Apple TV would need connecting to a DAC for best quality.
Hope one of these options will help you...
Eloise
Posted on: 14 September 2010 by sjw
thank you very much
the last option sounds best
cheerio
