CDR-Audio blank discs
Posted by: Rockingdoc on 26 November 2002
Being a bit of an audio Luddite, I didn't know that there was a difference between data and audio CDR and CDRW blanks!
I see CDR data blanks everywhere, but can anyone advise on a good source (UK) of Audio blanks?
thanks
malcolm
thanks
malcolm
Posted on: 26 November 2002 by Simon Crosland
There is a difference, but it is only relevant for "consumer" recorders - the ones that the pros use take the computer style blanks.
Anyway, digression over, try www.protape.co.uk and select the "CD-R Audio" option in the main "CD-R" section. They'll be about £0.50 per blank in quantity.
Simon
Simon
Posted on: 26 November 2002 by Rockingdoc
Excellent, just what I was looking for.
Many thanks
malcolm
Many thanks
malcolm
Posted on: 26 November 2002 by Andrew L. Weekes
The 'audio' discs are for consumer CDR decks, they are a bit more expensive as they have an additional levy to cover copyright issues.
Some decks can use PC discs...
Andy.
Andy.
Posted on: 26 November 2002 by Stephen Rodrigues
Cheaper still is www.pricebuster.org.uk
Or phone them on 0870 800 3444.
"...support your local independent dealer!"
Posted on: 26 November 2002 by AussiePete
I have done many comparisons with cdr and cdr-audio in computer burners and there is a vast difference in sound quality.
regards,
Pete
regards,
Pete
Posted on: 27 November 2002 by Steve Catterall
if you're not too bothered about not buying well known brand names like TDK and Sony this site is very good. I burn alot of CDRs and I've not had a problem with the disks. For instance they have Traxdata 40x 80m CDRs at under 20p each
I have done a lot of comparisons too, and while I agree that there are differences, as long as you get a decent brand I wouldn't say the differences were very big. I find there are much greater differences to be found in the CD burner that you use.
Posted on: 01 December 2002 by AL4N
I to have noticed a difference,DataTrack Gold disks £1 at pound land sound far better than Grundig multi speed at £1 for 2. There is also far less jumping if any on the DataTrack gold.
Alan
Alan
