DVD writing software for Vista
Posted by: Diccus62 on 11 February 2008
A friend wants me to copy her baby dvd's for family. Is there any software you could recommend, pref free. I thought windows might be able to do it but i'm not sure.
Thanks folks
Diccus
Posted on: 11 February 2008 by 555
Biggus yerself up Winker
I use nero for CDRs (doesn't do DVD rec) & it works V well.
I think it came with my copy of XP, but if not was free!
I know there are nero vers' that do DVD, & no doubt they have trails at nero dot com.
I have a handy FIL guide to Windows Movie Maker (prog' is free with XP). Could Vista have a similar freebie? This guide might have clues. If you'd like a copy of t'guide email me.
Posted on: 12 February 2008 by Diccus62
thanks, i'm giving up on it, seems too much like hard work Eek
Posted on: 12 February 2008 by 555
So I did more work replying to your thread than you did copying the DVD! Winker
No I hunted around, downloaded 3 programmes none of which seemed to have worked (probably me) and then gave up without too much of a fight.................. thanks anyway.
Diccus Smile
Posted on: 12 February 2008 by Guido Fawkes
You need the PC equivalent of MacTheRipper
Posted on: 13 February 2008 by Diccus62
...............................which is ?
Posted on: 13 February 2008 by 555
Here
Posted on: 13 February 2008 by ewemon
Thanks folks
Diccus
Send them to me and I will do it for you.
Ewan
She wants loads of copies for grandparents etc. She can get it sorted locally. thanks for the offer tho, v kind as always Smile
