Sourcing BNC's for Ittok (Follow-on from LP12 action ...)
Posted by: DIL on 06 May 2002
Will any old BNC's do, or are particular makes recommended ?
/dl
Posted on: 06 May 2002 by Rico
I used the standard Naim-supplied AMP brand ones - "MACOM (an AMP company... made in the UK... B35A70E010X" is all the detail on the wrapper if that's any help. They work nicely with the Ittok cable.
Try your dealer, or contact Naim directly failing that.
Rico - SM/Mullet Audio
Posted on: 06 May 2002 by Andrew L. Weekes
David,
Naim use 50R BNC's and I'd also strongly recommend sourcing the Tyco / AMP / M/A-COM parts. The Naim ones use silver plated body and centre contacts.
Use cable clamp / solder types (as per Rico's part number), not only are these much easier to assemble than almost any other manufacturer, they are more secure.
Farnell sell them (www.farnell.com) p.no. 309-266, although it states 'Only until stocks exhausted' which probably means M/A-Com have discontinued this part for an identically-performing new one (that uses less material and is lighter).
Andy.
P.S. Rico - did you get my email?
Yes, sorry Andy rude of me not to reply sooner. Will send you a missive tonight. Cheers!
Posted on: 14 February 2003 by --duncan--
Folks,
Having gone from a Nait 1 rather rapidly to an 82 I'm looking to ditch the BNC/phono adaptors on my Ittok lead, but I’m having no joy in sourcing the M/A COM BNC's. I've tried various websites suggested here and elsewhere. A well-known north London Hi-Fi emporium tried to sell me some horrible large gold-plated numbers. Another well-known central London establishment (think "soggy") suggested the adapters make no difference. No harm or great expense in trying a hard-wired plug and I can make my own mind up. A call to Naim elicited the suggestion that I try RS but nothing very specific (to be fair, I may have mistakenly given them the impression that I have some competence or knowledge in this area). Can anyone suggest either an up-to-date source for the M/A COM's or the most appropriate alternative amongst the many in the RS catalogue.
Many thanks in anticipation.
duncan
Email: djcritchley at hotmail.com
Posted on: 14 February 2003 by syd
I recently tried to fit BNC plugs (The ones that came with the preamp) to a cable and found it very difficult to dress it neatly. I never got to the soldering and eventually got it done by a professional with the right equipment and tools. I'ts definately a lot more difficult than RCAs or Dins.
Yours in Music
Syd
Posted on: 14 February 2003 by Vinylman
Big Grin
BNC FOR ITTOK ARM CABLE
I have done this to my Ittok LV2 by soldering
Silver plated BNC´s from "RS".
The BNC i used was the Greenpar Silver plated
423-1927 (1-1478401) 50 ohm.
I soldered with normal Multicore solder(60-40).
Instructions are printed on the BNC´s package.
It will help if you have someting to clamp the cable so it will be still when soldering.
This is the most cost-effective upgrade I have done.
Good Luck!
Posts: 1 | From: SWEDEN | Registered: MONDAY 28 October 2002
Posted on: 14 February 2003 by Not For Me
maplin also do 50 ohm solder BNC plugs.
I replaced with Ittok with these, and it works fine.
DS
Posted on: 16 February 2003 by RichardHallman
David, have you a part number for those Maplin solder BNCs?
Posted on: 16 February 2003 by jes0369
Hi,
I bought some from here:
http://www.custom-cable.co.uk
BNC plugs are an essential upgrade, just be sure to avoid any crimp on ones.
James
Posted on: 17 February 2003 by --duncan--
Thanks to all who responded.
Farnell carry a TYCO/AMP BNC plug part number 1-1478401-0. I presume this is what I am after.
duncan
