W-DOG?
Posted by: michael1702 on 28 January 2007
hi,
last time in the dark i pushed the wrong buttons on the remote and my dvd5 displayed W-DOG. i had to turn it off.
curious as i am i just want to know which depth of the dvd5 i reached. (-:
thanks,
michael
Posted on: 28 January 2007 by 110dB
Hi Michael,
W-DOG = Watchdog
Watchdogs are used on all well designed processor systems and it is used to monitor the processor. If the processor stops the watchdog will tell you.
On some systems such as computers and digital gadgets the watchdog is designed to automatically reboot the system when it detects the processor has stopped.
Posted on: 29 January 2007 by AV@naim
michael1702,
what is your firmware revision?
press and hold PROG for 5 seconds, front panel will display:-
C0101
M0007
C0206
06112
for latest firmware
watchdogs are generally supressed on latest firmware, so I suspect you have earlier version.
If so please contact your dealer to update it.
Posted on: 29 January 2007 by michael1702
Originally posted by AV@naim:
michael1702,
thanks for the replies!
i have the latest firmware. but as everything is fine it´s good to know there´s someone watching over my dvd5. ;-)
If you can tell me the sequence of events leading up to the WDOG message, then I will be able to help you a bit more.
Posted on: 30 January 2007 by michael1702
i can´t remember but i think it was "open" and "menu".
