Target VR4 good ? (in between Kan's)
Posted by: Alco on 09 October 2001
On my way home this afternoon,I stopped at a local warehouse,to check out some new CD's.
On the topfloor they have the "HiFi"-store.
When I walked by I saw a Target VR4 equipment-support. As I looked at it for more then 10 seconds a salesman came my way. He measured the rack and actually I'm now thinking of buying it.
When the salesman saw me in doubt he suddenly even lowered the price with UKP 30,-!
(now it's only UKP 170,-)
It's 60 cm/24 inches high,with 4 MDF shelves.
(15cm/6 inches in between) Now,to me it looked better then my current Sound-Factory rack and also it will hide more cables.
Is there anyone who uses/used this (kinda) Target Rack with Naim stuff ?
Now, another thing that may keep me from buying it is: I would place my CDX on the top-shelf,with spikes underneath the rack,the total height would come to 74cm/30 inches, and it would stand in between/front of my Kan's.
Would this have a bad influence on the soundstage,since the Kan-II stands are only 55cm high ?
I know from a topic I posted a while ago that it's a bad thing to place a TT on this height level,but does the same principle go for a CD-player ?
Greetings,
Alco
